Blowin H1 bulbs
Old May 23, 2006
02CivicDX's Avatar
02CivicDX is an unknown quantity at this point
Blowin H1 bulbs
I got the TYC halo projectors and i'm after blowing 4 sets of H1 bulbs in the last week. Any idea what would be causing it? Had 2 blow tonight 1 at first....then 10 mins later the other one went.
I'm was using the the blue H1 generics you get off ebay for cheap. Just like these
http://cgi.ebay.com/ebaymotors/H1-XE...68697388QQrdZ1
Any input would be appreicated or another type/brand of bulb to use.
Old May 24, 2006
topsecretjapan's Avatar
topsecretjapan is an unknown quantity at this point
i got the same problem. its the cheap blue bulbs i blow the most. if i run just regular h1 bulbs without the coating im fine, but when i go blue they blow. is it always your passenger side bulb?
Old May 24, 2006
PunkingCivic's Avatar
I need TP for my bunghole
go with name brands.
Search here for comments from other members about products: http://www.7thgencivic.com/parts_reviews/
Old May 26, 2006
uh yea your bulbs suck. the coating traps alot of heat and causes it to blow. try some OSRAM silverstar clear bulbs.
Old May 26, 2006
R1Style's Avatar
Make sure you're not touching the lens of the bulbs before you install them. Any dirt/oil on the glass lens will cause them to blow prematurely.
Old May 26, 2006
Hey gearbox, where did you get yours in the U.S.?
Old May 26, 2006
ebay lol
Old Jun 2, 2006
02CivicDX's Avatar
Always the drivers side blows first with mine
Got these for it now
http://cgi.ebay.com/ebaymotors/01-03...70433615QQrdZ1
Got lots of good luck with these in the stock headlights. Hopefully they will be just as good in the angel eyes
Old Jun 10, 2006
Civic99's Avatar
Civic99 has a little shameless behaviour in the past
looks great!
