quick question about 01-03 fogs?help ASAP
Old Mar 27, 2006
rally2001gt's Avatar
rally2001gt is an unknown quantity at this point
hi .. i need some help on my 01-03 fogs... i bought these fogs from tornactive.. i did use the search button and i came upon the the diy from bellz ... i have an automatic civic 01 but the one they used on the diy was a manual .. ok on the diy it says
There are two connectors on the harness that plug into the fusebox on the left side above the blackconnectorsThere's a diagram in the instructions showing exactly where they plug. If I'mnot mistaken, there's only one place that each can go. There's another ground to mount onthis part of the harness. I mounted it on the lower right corner bolt of the fusebox
i only saw one connector that properly goes into the fuse box
which is number 3.. my cousin then took the other conector and just clipped it into number 2 by pinching the 2 prong into 1
ok the fogs work but the switch for the fogs is always lit up even when the cars power is off.. what should i do.. is this normal
and help is greatly appreciated
i am new to this thanks
15EXCoupe
Jul 30, 2015 12:59 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
NoobyKid
Jul 13, 2015 07:53 AM
Enigma346
Lighting
Jul 12, 2015 08:24 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
