LED Bulbs shaving? (WITH PICS)
Old Mar 12, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
in diskreets DIY i noticed he bought bulb covers to make the light less distracting and so bright...i was reading ledautomotives buyers guide and they have these pics
Un shaved
Shaved
Now the question is....how do you cut the bulbs or "shave", seems like a good idea to have a nicely even lite dash. im asking becuase i bought 13 leds from http://www.superbrightleds.com/cgi-b....32127&next=50
and they arent shaved...i dont want them to look so bright and be able to tell where the bulb is. i also noticed diskreets pictures showed some spot brighter which showed where the bulb was and other spots dimmer. so if anyone can tell me where or how to get the bulbs cut i would appreciate it
oh and the part is ,......T1.5 Instrument LED bulb
Last edited by boxcarracer; Mar 12, 2006 at 03:35 PM. Reason: Automerged Doublepost
Old Mar 12, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
i used 60 grit sanpaper when i shaved mine down, but it took forever. Best way is to use a dremel with a little sanding drum down. make sure you have a few extras. the first few i shaved down too much and hit the diode.
shaving does diffuse the light a good deal. women and leds, better shaved
Old Mar 12, 2006
you can use lower grit for faster job. just sand the tops down but not too far. don't wanna damage the metal pieces inside. oh and sanding will greatly reduce the light output, altho speading it out. Just make sure you have leds that are bright enough to start with.
Old Mar 12, 2006
HonCivX02's Avatar
HonCivX02 is an unknown quantity at this point
yup.
Old Mar 12, 2006
ramcosca's Avatar
Words on a User Title
Damn, this would make me wanna shave the lights on my dash...
Old Mar 12, 2006
sandpaper? ...oh man i gotta sand down 13 bulbs? cant i just cut it with a sword? anyone got anotehr idea?
theres gotta be another way besides sand paper anyone else got an idea...a safe way, to cut these bulbs
Last edited by boxcarracer; Mar 12, 2006 at 10:39 PM. Reason: Automerged Doublepost
Old Mar 12, 2006
well they sell lil covers at superbrightleds.com that go over the led and diffuse it. or just try needle nose pliars to break the tip so its chunky. but you run the risk of breaking plastic off the led and ruining it.
Old Mar 13, 2006
dp_yz713's Avatar
Boobies are the mans tinkertoys
dp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to behold
yah i have those leds from ledautomotive. believe me they are not shaved or sanded down from a regular one. these are totally differnt and mines were not even close to that brightness. i have some leds like the unshaved one you posted and that thing can light up a room, but the flat head shaved ones dont put out much light, and deffinately spreads the lgiht better.
Old Mar 13, 2006
rest assured my pnp dash lights will light up two rooms. Still working on those in white, and then maybe pink and blue.
Old Mar 13, 2006
dp_yz713's Avatar
so gear your kit will have them all wired into to one positive and one negative that will just tap into the red and red/black on the plug right?
Old Mar 13, 2006
actually, it will be a plug and play kit. you remove your stock bulbs and replace with the led version, wired in a NEW socket. complete swap and you don't have to mess with soldering resistors or ruining your stock holder and bulb. the only way it will work right is if the led is bright enough, which it should be, and I may get some lens for them too.
Old Mar 13, 2006
dp_yz713's Avatar
Sweet!!
Old Mar 14, 2006
paradoxblue's Avatar
dim them. sand paper or a pair of plyers. snap the tip. tiss how i did it
Old Mar 15, 2006
R1Style's Avatar
Use a dremel with a sanding bit. You coud probably shave an LED down in 30 seconds with one.
thatcham
Sep 30, 2015 08:28 AM
frank_kleng
Sep 29, 2015 10:55 PM
MamaBear2015
Sep 24, 2015 11:34 AM
shaejb15
Sep 12, 2015 01:02 AM
MamaBear2015
Sep 4, 2015 09:04 PM
