third brake light.....the one in the rear window
Old Dec 31, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
mine went out the other week, i replaced the bulb and checked the plug itself but it still isn't coming on. i would fidget it around a little and it would come on but then nothing...where do i go next?
Old Dec 31, 2005
saugashan's Avatar
This is not my batman glass!!
saugashan should not be trustedsaugashan should not be trustedsaugashan should not be trusted
fuse
Old Dec 31, 2005
shroomster's Avatar
Originally Posted by saugashan
fuse
interior or engine bay?
Old Dec 31, 2005
jttegx's Avatar
OMNES AD UNUM
do you have the owners manual?
it shows what fuse is what in their
Old Dec 31, 2005
CraigW's Avatar
Other brake lights working = fuse o.k. I would try cleaning the socket contacts and check the bulbs fit.
Old Dec 31, 2005
shroomster's Avatar
yeah i did the socket contact cleaning while fidgeting it....there is voltage going to the socket as well, as i pulled the new bulb while the brake was pressed and it arced a lil electricity....this is pissing me off hehe....
Old Dec 31, 2005
CraigW's Avatar
Has to be a simple connection problem. Try a different bulb.
Old Jan 1, 2006
seems like a wire is loose or something
Old Jan 1, 2006
shroomster's Avatar
haha...turns out it was the bulb....technically the 5th bulb.....ok so here is what happened i noticed it was out, went to discount and bought some hyper white bulbs as that was all they had. i tried it at the store and it didn't work so i took them home to try them there, thats when i realized i could use the reverse lights as they were the same bulb type. i put one in and it came on and went back off....I replaced the two reverse lights with the hyper whites and went about my business as usual. yesterday I decided to check again. i pulled the new light and tapped it against my palm, i get a vibration, damn element blew in the second light, so i take the final of the original reverse lights and stick it in and problem solved....whole time I was thinking a wire was loose...
flame away hehe
at least now I have some white reverse lights instead of that rosey color the enclosure is...
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
bsmiley
Apr 27, 2015 01:27 PM
clockwerx
Dec 13, 2001 12:39 PM
BamBam
Dec 8, 2001 02:21 PM
