65 watt bulbs ok?
Old Dec 29, 2005
spoonEM's Avatar
omgwtfbbq mod.
65 watt bulbs ok?
Well i got my ebay fogs for my 04 and they came with h8 bulbs. Im gonna put in some h9's since theyre the high beam bulb, and theyre 65 watts....do you think ill be ok?
Old Dec 29, 2005
caytana1's Avatar
caytana1 is an unknown quantity at this point
fog light bulbs
I got the 04 fogs with laminx and 50 watt h8 bulbs and I was wondering the same thing because I was running these for like 10 minutes and I touched the foglight and it was pretty hot.
Old Dec 30, 2005
EastBayStuntN's Avatar
EastBayStuntN is an unknown quantity at this point
i will never put an higher wattage bulb in a projector thats not meant to handle it. same goes for using different application bulbs.
i bought some piaa foglamps that use an h3 bulb rated at 35w. i went ahead and bought a set of h3 piaa bulbs that were rated 55w hoping i will get much better light output and i did. eventually, the 55w bulbs heated up and melted the surrounding sealant on my foglamp lenses.
so whatever decision you make, try not to make the same mistake as i did
Old Dec 30, 2005
dtox666's Avatar
dtox666 is an unknown quantity at this point
I used to do the same with my old Ford Escape: running 50w bulbs when I was supposed to use 27w.
Luckily nothing melted or burned, but even then the bulbs would only last a few weeks before they burned out...
Old Dec 30, 2005
spoonEM's Avatar
omgwtfbbq mod.
hmm...im just pissed that my fogs arent bright....i mean...it looks like my battery is dying. haha. and no...i didnt hook them up wrong, just they arent that bright.
Old Dec 31, 2005
jttegx's Avatar
OMNES AD UNUM
fog lights arent suppose to be bright as you think..like your car headlights. but i'd be pretty pissed if they didnt do well in the fog haha
Old Dec 31, 2005
spoonEM's Avatar
omgwtfbbq mod.
haha....exactly. I dont want them blindingly bright....just a nice bright yellow. I guess ill try it out and see what happens.
Old Jan 1, 2006
if you want yellow get the nokya 55w 2500k bulbs
Old Jan 1, 2006
spoonEM's Avatar
omgwtfbbq mod.
thats what im talking about.....but the package says 65 watts
Old Jan 1, 2006
check the bulb itself for actual wattage. mine said 55w on the bulb and 80w on package. the stage 1 are all stock watts i think.
Old Jan 1, 2006
spoonEM's Avatar
omgwtfbbq mod.
sweet...i think im gonna do the h9's since its the brighter version. lol
Old Jan 1, 2006
the nokyas already look alot brighter than stock. i wouldn't risk putting hi wattage cause its hard for heat to escape the fog light
Old Jan 1, 2006
spoonEM's Avatar
omgwtfbbq mod.
good idea...i guess ill just stick to h8's then.
cferry7
Oct 18, 2015 06:32 PM
shaejb15
Sep 12, 2015 01:02 AM
MamaBear2015
Sep 4, 2015 09:04 PM
msaeger
Sep 2, 2015 08:47 AM
