DIY LED Gauge Cluster II
Old Mar 12, 2006
  #61
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
wow 106k miles where do u go everyday?
Old Mar 13, 2006
  #62
hdave's Avatar
hdave is an unknown quantity at this point
hey utahbmxer... did you sand down those LEDs before putting them in your cluster??
Old Mar 13, 2006
  #63
utahbmxer's Avatar
utahbmxer is an unknown quantity at this point
Its 107k now, Both work and the girl-friend (2 years) are about 20 miles away. I drive back a forth a few times a day. It sucks to, cause I am riding on the stock struts and they're getting pretty bad. I can feel the wheels bouncing off the road over bumps. I hate the roads here.
I was going to buy some KYB GR-2 struts this week but I just got home from BestBuy. Bought the lady a iPod video for the heck of it. So those will have to wait til next week. My poor car has been through hell. 2 bad accidents (should have been totaled between the two adding upto about $9,200 in work). Messed up alignment from body shop which screwed my tires up (never reimbursed for new). Cracked exhaust manifold that stinks up the heater. Rebuilt the 5spd. There is alot more, but this isn't the right thread, so I'll stop now. LOL
I used a dremel with a super fine (almost polishing) bit. Just flattened the head so there is pretty much a 90 degree edge. I also took the little lip off the base of the LED so it would fit in the socket thing.
Old Mar 14, 2006
  #64
dp_yz713's Avatar
Boobies are the mans tinkertoys
dp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to behold
so utahbmxer your needles are blue cuz you used the leds in the back the cluster to light them right? or did you put some in specially for the needles cuz i am still deciding what i want to do
Old Mar 14, 2006
  #65
with your setup (cleared needles), you would just need to put leds below the needles or into the light guides.
Old Mar 14, 2006
  #66
dp_yz713's Avatar
cool. i will have to find me some red ones and get some white glass paint. i just colored them red right now adn they are fine but not bright enough
Old Mar 15, 2006
  #67
utahbmxer's Avatar
All I replaced is about 5-6 LEDs in the back of the cluster that light the faces and needles. I was thinking about adding some LED's behind the needles (in the guides) but after I sanded the needles and put white paint on the back of them, they were actually pretty bright.. so I haven't put any behind the needles yet.
Old Mar 15, 2006
  #68
dp_yz713's Avatar
sweet bro good job
Old Mar 21, 2006
  #69
im not putting on sleeves to dim the light.....will i become blind? i got the bulbs 13 of them.....thats correct for a manual car right? theyr all the same??! please say yes becuasei got 13.... and climate control kit they will be one soon along with double pod cluster
Old Mar 21, 2006
  #70
i have no idea what you just said
Old Mar 21, 2006
  #71
dp_yz713's Avatar
i think he doesnt want to use the cover, but then it will just look stupid not blind. and yes it is the same for manual or auto cluser
Old Mar 21, 2006
  #72
diskreet's Avatar
if you don't use the covers it is pretty bright. with them its a little more dissipated than before and a little dimmer, but not by much
Old Mar 21, 2006
  #73
what cover??
Old Mar 21, 2006
  #74
dp_yz713's Avatar
the bulbs covers for the leds in the gauges
Old Mar 21, 2006
  #75
i'm still lost. you mean covers he bought and put on the leds he stuck in?
Old Mar 21, 2006
  #76
dp_yz713's Avatar
yah on the ones in the gauge cluster to dim the hot spots and lights some. i believe this is what hes talking about cuz thats what diskreet suggest on this thread when he wrote this
oh and gear, i dont have my projectors but to just test my H1 Osrams, can i hook up a positive wire to that little plate the wire goes on to try it? but what about a ground cuz i know its on the side of the hole where it mounts in the projector.
Old Mar 21, 2006
  #77
i thought the power is the spade terminal and the ground is the base of the bulb. I know cause when I had it plugged in and trying to stick it in the hole, it kept touching the chassis and lighting up.
Old Mar 21, 2006
  #78
dp_yz713's Avatar
hmmm, not sure. but its cool. i guess i will just wait till i get my projectors back
Old Mar 22, 2006
  #79
it will look stupid? u tried it ? i didnt buy bulb covers....but if i dont put covers on and make my guages clear will the brightness make it so its not so noticeable with dark spots? i wanna see a pic if anyones got please showme
Old Mar 22, 2006
  #80
just use paper pieces over the hot spots to even out the light.
Old Mar 22, 2006
  #81
dp_yz713's Avatar
i didnt try but, but it just seems that if its too bright then it would look blue and not too clear. just imo.
Old Dec 20, 2009
  #82
iam.alnz's Avatar
iam.alnz is an unknown quantity at this point
Re: DIY LED Gauge Cluster II
Hello there, your post is very helpful and good and very much appreciated. May I ask... My honda civic is 2005 model VTI-S, dimension body with led illumination already. It was flooded all the way up to the dashboard...(sigh) when i have started it after some repairs and parts replacement, the RPM in no longer illuminated, only the KPH and FUEL/TEMP gauge are lighted. My question is "How to remove the needle in order for me to replace the LED inside" will it be the same that I only have to pull the needle up? I have tried to pull it up but it's very tight ang I was afraid that I might broke it or I can never return it.
Please help...
Thank you very much in advance.
Old Dec 20, 2009
  #83
the newer clusters will break if you try to dismantle it by pulling the needles out. the only option is look for another replacement part. do you have a pic of your cluster?
Old Dec 20, 2009
  #84
iam.alnz's Avatar
Hello, I don't have pictures but it's the same model civic 01-05 7th gen. Only that it is already LED lighted. Please help me on how to open the gauge at the front and replace the led's. I can not afford to buy a new gauge bec I have already drained my pocket with some parts like ecu, airbags, fuse box, etc. I want to repair my gauge.
thanks
Old Dec 20, 2009
  #85
iam.alnz's Avatar
Hello< I have atteched here picture which I got from the internet. This is the same as mine. Please check if I can remove the needles by pulling it up. Thanks
Old Dec 20, 2009
  #86
yeah those are the ones that cannot be opened. i tried once on a spare, and the needles would not go back in. the fuel and temp were very loose and would not work at all, the tach and speedo went back in but would not read properly and were jumpy. so it wont work taking it apart. and even if you do, you need special SMT (surface mount) leds which are very small and expensive. i have seen those clusters on ebay for $50-65 shipped. i dont think thats too expensive, it might be hard finding one with similar mileage but just take a look. you can try opening it for fun, but like i said it will be useless once you try and reassemble it.
Old May 30, 2012
  #87
concepttheman's Avatar
concepttheman is an unknown quantity at this point
Wow 3 years. So let me get this right. I put the bulbs in with the sleeves and sand the needles down, then apply glass paint to the needles, and i'm done?
Please explain any steps i missed. Thanks. Nobody will probably answer but i tried.
Old May 30, 2012
  #88
diskreet's Avatar
That's all I did. Haven't owned that car in a few years but I remember this well. Was a fun project.
If you need more help pm me or email me with my user name @Gmail.com
hondacivic0253
Sep 29, 2015 08:06 AM
Klame9420
Sep 18, 2015 12:37 PM
srtlat
Sep 17, 2015 11:02 PM
rayman009
Sep 12, 2015 08:30 PM
