For all those with OEM Style fog light problems!
Old Jul 19, 2005
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
This will be especially helpful for the people who have wanted to install fog lights but are scared of having problems. It is SUPER easy as long as you get the right kit. there are two that I know of on eBay. First I just bought a random set of fog lights from eBay figuring they where all the same. Well the set I bought turned out to have the wrong harness, AND the switch would only fit the location of the cruise control/ sunroof buttons UNLESS you have a 2001 which has a different hole for the switch above the center console. That would not work for me because I have a 2002 EX so the only spot I could put the switch was above the center console near the 12v power port. So I decided to take the risk and buy another set on eBay. This time I was on the lookout for differences, here are the differences that I noticed...
1 The 2001 set of fog lights has a totally different harness. The one you need is pictured
2 The area on the actual fog light surrounding the lens should be gloss black instead of textured.
3 The back of the light housing should be a brown color NOT gloss black
4 The wrong kit came with a switch (a REALLY crappy one) and with the correct kit I had to buy the switch from Honda.
The stuff that didn’t work for me was from this auction. http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Here are the good ones. http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Once I got these everything mounted right up and plugged right in.
PLEASE REMEMBER this was for a 2002 EX Coupe. The first set I bought could very well work with the 2001 but not likely with the 02-03
I hope I helped someone in need.
Old Jul 26, 2005
ironcow's Avatar
ironcow is on a distinguished road
thats great info...thanks so much
Old Jul 27, 2005
TuRtLE714's Avatar
TuRtLE714 will become famous soon enoughTuRtLE714 will become famous soon enough
its weird...cause i got a depo kit and i also bought a 02 fog OEM switch and it doesnt fit the socket. so im stuck now with it and the sockets for the switch on the depo dont fit correctly
Old Jul 28, 2005
dopes6070's Avatar
maybe you could take a multimeter to the pins in the switch and the wires and figure out how to wire it up. then just solder the wires to the switch.
Old Aug 1, 2005
2001 Civic EX's Avatar
2001 Civic EX is an unknown quantity at this point
Cut out template
Did the kit you buy have a cut out template for the bumper? If not how did you make the cuts in the bumper. The fog lights look very good and very clean job.
Thanks,
Jason
Old Aug 1, 2005
dopes6070's Avatar
I used this to help out with the install.
03 Civic fog lights
I just kinda eyeballed the drawing of the cutout in the pdf. They fit perfectly
Old Aug 4, 2005
scrimp's Avatar
scrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of light
I have a 01 LX. I was planning on buying some fog lights. So, do u think the wire harness for the 02-03s will work on an 01?
Old Aug 4, 2005
dirtySAMURAI's Avatar
I log in from time to time
the harnesses will work in any year car, afaik. the only problem with the harnesses is that sometimes they will be the correct length and come with the correct push-button switch, other times they will be too short/not go where you need it to go and come with too large/too small of a button.
Old Aug 4, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
my 01 lx had no problems with the switch reaching to where the cruise control button is. but i did just install the power and ignition into 2 dist. blocks i installed behind the hu. much easier to install the power and ignition by splicing rather than using the harnesses.
Old Feb 18, 2008
djacs's Avatar
djacs is an unknown quantity at this point
Re: For all those with OEM Style fog light problems!
This looks like exactly what I need BUT I can't get the pics to work and the ebay threads go to old expired items that I can not view.
Can anyone update this so I get the better fog lights for my 02 LX?
Old Feb 19, 2008
electric130's Avatar
seeing how this thread is 1.5 years old, i seriously doubt you're going to get anyone to update it. OEM fogs are all over ebay. just search. anyone else is going to have to search just like you will.
Exterior
Nov 28, 2025 05:23 PM
CivicS
Nov 22, 2001 10:51 AM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
