Turning off the daytime running light??
Old Oct 13, 2004
Asteroid's Avatar
Asteroid is an unknown quantity at this point
Lightbulb Turning off the daytime running light??
Hi there, wondering if I could turn off the daytime running light. Which fuse should I pull out? Cheers.
Old Oct 13, 2004
Yoyoio's Avatar
Yoyoio is an unknown quantity at this point
i was told is a 10amp fuse.. thatz about it.
Old Oct 14, 2004
Asteroid's Avatar
Thanks man, will try.
Old Oct 14, 2004
It's more complicated than that. Alot more complicated. The dealer can turn it off for you, since there's no law stating that the system is required.
Old Oct 14, 2004
Asteroid's Avatar
Oh really? Thanks a lot.
Old Oct 14, 2004
TeLLy's Avatar
Yes, it's an Acura EL
True, but talk to EL-Sport - I think it's actually two fuses you have to pull, but I don't see it being any more work than that.
Old Oct 14, 2004
silverem2's Avatar
I have mine off in my car, as i have 350z hid in my car . To turn the drl off you need to go underneath the dash to the fuseboard and find where it says drl lights, and pull it. It is a 7.5 amp fuse. This will stop your drl light from comming on and from them comming on period
Old Oct 14, 2004
What about the other stuff tied to the fuse? I think the fuse also controls one of the headlights or something.
Old Oct 14, 2004
TeLLy's Avatar
The fuse is tied to the high beams, but you shouldn't lose high beams if you pull the fuse.
Old Oct 14, 2004
Asteroid's Avatar
I found and successfully pulled out the fuse, thank you!
Old Oct 16, 2004
Asteroid's Avatar
Thanks man.
Old Oct 16, 2004
silverem2's Avatar
do you live in canada? or have a car that has drl? Cause the vehicles in the USA are not equipped with drl. Did you go underneath the dash? Its underneath where the steering wheel is, if it didnt work, you probably pulled out the wrong one. And to answer the othe question, no there is nothing else tied to the drl. If you pull the fuse, that acts as if the current went wacky in there and the fuse blew, resulting in no power being fed to the drl. And yes, your high beams still work.
Old Oct 16, 2004
silverem2's Avatar
The drl is a unit that feeds 1.3% of your actuall high beam power to light up during the day, also, by pulling the drl, you save your bulbs life by not having to burn that bulb.
Old Oct 16, 2004
Asteroid's Avatar
Thanks for your help everyone!
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
prowl
Apr 18, 2015 07:50 PM
gabrown2
Apr 11, 2015 08:22 PM
supercivic01
South
Nov 30, 2001 11:27 AM
cazminn
Nov 9, 2001 11:18 AM
