DIY: Complete 04 taillight conversion!
Old Feb 25, 2006
  #91
jdm_veloz's Avatar
jdm_veloz is an unknown quantity at this point
Originally Posted by Hurts2bStock
I know this is a semi-old thread and topic but, I couldn't find the adaptaplug thing.......so I just cut the plug to fit the new socket, it took about 45 seconds per plug and now they fit as good as oem ......
will the cut the plastic work as well? like does is still light up properly?
Old Feb 27, 2006
  #92
vietstylez's Avatar
everything lights up like oem, i havent had any problems with socket falling out or anything either.
Old Feb 28, 2006
  #93
Hurts2bStock's Avatar
Shinier than yours, meatbag
Mine works perfect, and the plug will fit very tight.......if your scured....I live in Van if you want some help
Old Mar 20, 2006
  #94
IrockCivics's Avatar
Originally Posted by zen_master
<Updated: 10/11/05 -- Now I'm not using this DIY anymore, I replaced the whole wiring to 04/05 wiring >
Hi guys!
This is going to be my first DIY for 7thgencivic.com.
(for complete DIY of the 04 tailight itself, go down...........)
In concern of the other 2004 Civic taillight conversion DIY, I went to Radioshack and was trying to find the required stuffs....like the cables, butt connectors, Y shaped connectors, etc..
However, I got a trouble finding the correct butt connectors that I want to use to connect the wire to the socket. After 30 minutes trying to find the right connector, I was circling around Radioshack to find something else that is simpler and easier to use.
I got this:
1. Adaptaplug 6" Power Leads -- $2.99 from Radioshack.
2. Socket number 33304-S30-003 from Majestic or Honda dealer. $4.55
3. 7443 Bulb from any local auto store (DOUBLE FILAMENT) $5.83
*Taillight DIY: Step1 (Image)*
the wire/adapter that I bought is a "Adaptaplug 6" Power Leads," with the pricetag of $2.99 from Radioshack.
As you can guess, it's absolutely simple to use this wire to accomplish our DIY.
*Taillight DIY: Step2 (Image)*
Installation procedure:
The only thing that you have to remember is the way you install the connector into the socket.
Look at the picture above, as you can see, I plugged the connector not just by simply plugging it into the socket. All you need to do is to plug the two connectors on the wire into the LOWER part of the metal pins inside the T20 socket.
Why do we connect it this way? This way, the Radioshack adapter won't wiggle around. If you plug the adapter straight above the metal pins (so easy), the connector can move around and the bulb won't light up. Instead of doing that, we plug the adapter below the metal pins, so that the adapter won't wiggle anymore.
*Tailight DIY: Step3 (Image)*
Then, you should know the rest of the DIY....It's a simple connection to our wiring harness into the hardened wire of the Radioshack adapter.
Voila! We're finished! Just like that!
*Taillight DIY: Step 4 (Image)*
From the picture below, you should realize how easy it is to do this DIY.
SO.....
here's how to swap your 01-03 "sad" looking tallight into the "happy" looking 04 taillight...
first, take out the fabric cover by unscrewing that plastic tab (use nail or supermarket bonus card)...
this is how my old 01-03 tailllight looks like from behind...
then...we've to unplug all the sockets from the housing....simply by turning the socket anti-clockwise...
the second socket from the left is the old turning light socket that we got a trouble with....how to change it? you can read the DIY above....
simply unscrew the 5mm lug nut by using socket wrench number 8......metric size...
there are total 4 of em on each side....
this is how my car looks like without the taillight....neat, eh? hahaha..
after this step, you just have simply do the DIY above....or another DIY to prepare the T20 socket that fits the 04 taillight...
after everything's ready....just put back the 04 taillight into your civic...and everything should be allright.....make sure to look after the plastic tab on the side of the taillight...don't break em..
on the picture below, this is how my wiring looks like right now...by using the Radioshack Adaptaplug...
i used the green wire clipper to hold the old side market that we won't use no more...
and this is the final picture..
you should see the happines of my car.....and the "sad" look of the old taillight!
notice the happy look of my wal-mart muffler tip?
more pics and more pics for your information...........
This is the one that won't fit:
Enjoy!
<Updated: 10/11/05>
Does this DIY still works for the conversion or is there a new and easier one? and sorry for bringing this thread back from the dead lol
Old Mar 21, 2006
  #95
kingofheartz's Avatar
kingofheartz will become famous soon enoughkingofheartz will become famous soon enough
i think theyre both pretty easy =P
Old Mar 23, 2006
  #96
blouisgod's Avatar
Life Begins > 6800rpms
christ someone put this in a DIY section or sticky. ****.
Old Mar 23, 2006
  #97
ive got a pair of 04 lights coming in this weekend, if i can get my car out of the shop in time to put em on before next week, ill post some pix for fun ^^
Old Mar 23, 2006
  #98
I am doing mines tomorrow, I will post pics when I'm done.
Old Mar 24, 2006
  #99
looking forward to seeing em
Old Mar 24, 2006
  #100
Here are they took me like 20mins to put them on very easy and yes I know I'm missing a bulb on the right reverse light lol
Old Apr 4, 2006
  #101
looks good, i love the look of the 04 tail lights.
Old Apr 4, 2006
  #102
thanks bro'
Old May 25, 2006
  #103
realitycheck's Avatar
realitycheck is an unknown quantity at this point
I have a question what if you took the new socket and cut this part
off could you not just take two wires and solder them to the two little pins that are sticking out??
Old May 25, 2006
  #104
zen_master's Avatar
hmm...that's also possible...
but the idea of this DIY is "clean" right?
i belive that cutting and soldering will make it UNclean....lol
Old May 25, 2006
  #105
hey it doesnt matter if noone sees it!
Old May 25, 2006
  #106
zen_master's Avatar
^true dat!
so, it ends up on your own decision.........
Old May 26, 2006
  #107
Seems like more work and less quality than the other two methods, but maybe thats just me
Last edited by Hurts2bStock; May 26, 2006 at 03:22 PM. Reason: Automerged Doublepost
Old May 26, 2006
  #108
Well this is my thought process the original diy I dont like cause it just doesnt seem as secure too me. The second one where cutting the plugs is involved it doesnt seem reversible. No offense against zen master these are just my thoughts.
The way im talking about I can solder it on which is not going to come off unless you brake one of the pins off. I can heatshrink everything together, and its reversible if I get rid of those taillights one day, back to the old sockets. All I have to do is use my wire stripper peel back the wires a little bit and then solder some extensions on the wires, then solder to the pins. Voila, done and reversible.
Old May 26, 2006
  #109
zen_master's Avatar
hehehe, definitely no offense or such thing, buddy
your idea is definitely do-able as well....any ideas for the DIY = great
Old Apr 17, 2008
  #110
zen_master's Avatar
Re: DIY: Complete 04 taillight conversion!
wow. it's been 2 years.
13,000 views?
Are there anybody out there still using this DIY?
(talking about thread from the grave...)
Old Apr 27, 2008
  #111
icedcoco's Avatar
icedcoco is just really niceicedcoco is just really niceicedcoco is just really niceicedcoco is just really nice
i just used the DIY..lol...
Old May 24, 2008
  #112
dafynesplaya's Avatar
dafynesplaya is an unknown quantity at this point
I wanna do this tail light conversion but I can't see the pics..hmm is it just me?? anybody got the same DIY with pics???
Old May 25, 2008
  #113
https://www.civicforums.com/forums/1...onversion.html
thaler4cuse
Sep 7, 2015 08:25 PM
Pier7866
Sep 6, 2015 06:54 PM
xeroid
Aug 31, 2015 10:53 PM
naokigoffi
Aug 30, 2015 06:19 PM
GritzNGravy
Aug 19, 2015 03:03 AM
