both headlights not working
Old Feb 29, 2004
adadani's Avatar
adadani is an unknown quantity at this point
ok i've got this major problem on my car, one day i get off work at night and i turn on my car and my headlights aren't working. the parking lights work, the turn signals work, and even the high beams work, but the low beams don't work. i checked the fuses, the fuses are fine, now i have no idea what to do because now if i drive at night, i have to drive with high beams and i can't keep trying to blind everyone on the road. does anyone know how i can solve this problem as soon as possible?
Old Mar 4, 2004
adadani's Avatar
i'm not dumb, that was the first thing i did, i replaced both headlights.
Old Mar 4, 2004
FALKEN's Avatar
Civicforums Junkie
are you aware of the recall on this issue??
Old Mar 6, 2004
adadani's Avatar
no, but i got it fixed, thanks for your replies!
Old Feb 15, 2008
testdrive's Avatar
testdrive is an unknown quantity at this point
Re: both headlights not working
ok, i have this same problem...i dont know what to do..i already checked the fuses but nothin...i did hear about the recall but not to sure what my next step is in this problem. can anyone help me please?!
Old Feb 15, 2008
do your hi beams work? if so, its prolly the recall. the wires in the oem switch burn out and then it wont work. what year is your car? i think it was recalled for 01 and some 02 civics.
Old Feb 16, 2008
electric130's Avatar
did you change the bulbs yet? don't just "check" them. change them first. that's the easiest thing to do before you go tearing things apart.
Old Jul 10, 2010
Hodie541's Avatar
Hodie541 is an unknown quantity at this point
Anyone happen to have the recall number? I have the same thing happen to my Civic.
Old Jul 10, 2010
post your email and i can send the recall .pdf document. or just pm me the email.
Old Sep 29, 2010
melmashman's Avatar
melmashman is an unknown quantity at this point
I have a 2005 Civic and noticed one front headlight out. The next time I drove it both headlights were out. The two fuses are fine. I did a Google search and found a recall for the 2002 Civic: 2. EXTERIOR LIGHTING:HEADLIGHTS
Recall Number: 04V086000
Dates Manufactured: N/A to N/A
Number of Vehicles Affected: 440000
Date Owners Notified On: N/A
Vehicle: 2002 Honda Civic
I am calling the dealer to see if the recall includes 2005.
Mel Mashman
mel@mashman.com
Old Sep 29, 2010
Mel Mashman
mel@mashman.com
did you try changing the bulbs yet? since both are installed at the same time, they operate together, it's perfectly normal that they burn out at roughly the same time. i bet its just your bulbs that are bad.
Old Nov 15, 2011
goodrich's Avatar
goodrich is an unknown quantity at this point
I have a 01 civic and have had the problem three times now, the solution, besides having Honda replace the part is take the switch assembly out of the steering column and you will find that the assembly is most likely covered in a light oil. If you take some methanol and clean the inside and outside very well the lights will work for about 6 months before you have to do it again. I am going to my local dealer tomorrow to see if they will fix this once and for all.
Old Oct 4, 2015
GRIZZLEY ADAMS's Avatar
GRIZZLEY ADAMS is an unknown quantity at this point
03 honda civic low beams out again,recall done,will honda replace switch
Old Jun 26, 2016
Jem2001's Avatar
Jem2001 is an unknown quantity at this point
so i have a 2002 honda civic sedan with sun roof my headlights dont work the highbeams do and the drl works i checked the contacts at the bulb terminal there is no ground going to the headlight bulb all three have power i just bought new bulbs and the same problem i have to drive with the highbeams for now at night but i want to get to the root of the problem i can simply by pass a terminal and ground it but that will take away the drl and i want to have drl and headlights working i flick the switch to the last and the side lights glow but no headlights im assuming the switch but i removed that to and didnt see any grease or anything that would be wrong but there is a recall i also replaced the drl with a known working one from my dads civic so what is your input
Old Jun 26, 2016
Did Canadian cars have a recall for the low beams quitting? The USA cars do.
Call your local Honda dealership and find out.
Old Jun 27, 2016
Jem2001's Avatar
well im not sure about the whole recall thing to be honest i just followed based off my diagnostic troubleshooting of changing fuses and bulbs and checking wires because all the fuses are good and relays are good so mehh on that ??
Old Jun 27, 2016
Cal your dealership, find out if your car needs any recalls done.
Old Jun 14, 2019
Amneet's Avatar
Amneet is an unknown quantity at this point
So what was problem mate
I got the same issue
Can you please email me Amubatth@yahoo.com
Old Jun 7, 2020
Dom1nofx's Avatar
Dom1nofx is an unknown quantity at this point
Old thread but new and decided to work on my brother's '03 civic lx - high and low beams aren't working but everything else is. Should I just start and replace the headlight switch because I don't think this recall would apply at this late in the game. thx
Old Jun 7, 2020
FRSam's Avatar
Click Here
If the recall was never performed, then it's probably still valid. I would call the dealership to see.
Old Jun 7, 2020
Recalls do not expire.
See links in signature:
Old Jun 7, 2020
Dom1nofx's Avatar
Thank you - I did check and it says 0 recalls. I'll try and replace the light switch anyway and see if this will fix his issue. Thanks again.
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
intensity
May 12, 2015 10:43 PM
ORskier
May 3, 2015 12:54 PM
bsmiley
Apr 27, 2015 01:27 PM
shaejb15
Apr 26, 2015 07:44 PM
