h4 bulbs
Old Jan 5, 2004
YS's Avatar
YS
YS is an unknown quantity at this point
h4 bulbs
i'm interested on PIAA 135/90 WATT H4 BULBS (clear, no blue tint) ..... it'll bright like hell ... it's the real 135/90 watt bulbs
questions:
1. 135/90 <--- does it mean High/Low or Low/High????
2. Will the Stock OEM headlights will hold?? will it melt the housing??
3. Will the stock wiring will hold?? will it burn out the wiring??
4. OR should i get the HELLA 100/80 Watt bulbs???
Thank you kindly
Old Jan 5, 2004
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
1. high/low 90W low beam.. and 135W high beam. I have never seen any dual filament bulb where the low beam has a high wattage than the high beam.. hence the term "brights"
2. They might melt the housing over time. when i ran my Polarg bulbs for over a year.. and took off my headlight housings to put my HID's in, the back was discolored. but they wern't near the wattage as what you want.
3. Now this one is probably a definate yes. Cause you'll be pulling almost twice the amount of current through those little itty-bitty wires. Same as car amps.. to pull more amps/current.. you need a thicker (heavier gauge wire) you try and run 135W through a little 18 gauge wire.. you're gonna pop it...
4. I would go with the hella bulbs.
And which ever bulbs you chose get this (at the top of the page on the left, click on the tab that says "Headlight Wire Harness" With those.. you'll be pulling juice straight from the battery with a thicker wire, so you'll be getting more voltage to the bulbs and thus brighter light. (but shorter bulb life).
Hope that helped some!
Old Jan 5, 2004
ImPulse's Avatar
Re: h4 bulbs
nm ^
Old Jan 5, 2004
Hefe's Avatar
whaa?
Old Jan 5, 2004
YS's Avatar
YS
"Boost the performance of your headlights by increasing the voltage to them. Especially for high wattage halogen bulbs, but will improve any bulb by 50% or more plus increase the white light component"
I've tried that $hit .... the bulb did not die ... it BLOW UP my bulb inside my headlight ... a lot of glasses stick on the reflectors and now i have to get a new headlight because i can not clean it up ... i've tried everithing but still not clean
Old Jan 5, 2004
Hefe's Avatar
or don't try that.... doh....
then stick with the hellas...
Old Jan 5, 2004
YS's Avatar
YS
thanks Hefe
Old Jan 5, 2004
YS's Avatar
YS
how about MTEC 4X H4 100/90 ... is that a good bulb??
Old Jan 5, 2004
YS's Avatar
YS
do you know a good & Cheap HID??? H4 high/Low HID ???? so far i only can find low HID only
Old Jan 6, 2004
Fern's Avatar
The Greatest
Fern is an unknown quantity at this point
"do you know a good & Cheap HID??? H4 high/Low HID ???? so far i only can find low HID only"
good and cheap cant be found. cheapest kits ive seen are like $300 and somethin, and are usually only low beam kits. spend the extra money and get a quality kit that has both high and low. Cause if you have to replace an HID bulb, they can run like $100 to replace them, and teh cheaper kits are usually the ones that burn out. Check the For Sale forum, someone was selling a used Hella Hi/Low kit for like $200 somethin, i was almost thinkin about buying it myself, but im strapped for cash right now.
cferry7
Oct 18, 2015 06:32 PM
shaejb15
Sep 12, 2015 01:02 AM
MamaBear2015
Sep 4, 2015 09:04 PM
mac25
Aug 21, 2015 11:14 PM
j-chest
Aug 11, 2015 02:26 PM
