Passenger Side Low Beam went out...
Old Nov 29, 2003
fraga's Avatar
Wicked Moderatuh
Angry Passenger Side Low Beam went out...
What should I do first. They are Polarg, and the Bright Lights still work. Now I know I've just read threads about people who went back to stock and this has happened. But I haven't touched the car recently or got into an accident, so my question is, if this was your car, what would be the first thing you do???
Yeah, yea, yeah, I probably should have searched, but I'm lazy as hell, and you guys can probably give me better advice to my particular situation. Thanks in advance.
Old Nov 30, 2003
Voiceofid's Avatar
End Bringer
jason, try chekcing your fuses
if not, then i would go swap to the factory lights first, and see what's up
Old Nov 30, 2003
fraga's Avatar
Wicked Moderatuh
Yeah, I still have an old Nokya that works, I was gonna try switching it out with that one, and if nothing, then I'll be posting here again...
Old Nov 30, 2003
ImPulse's Avatar
each headlight gets its own 15? fuse
So, if your highs work... Then the fuse is fine... The fillment is mostlikley ****ed up, So u need a diff bulb
Old Nov 30, 2003
fraga's Avatar
Wicked Moderatuh
That's what I'm thinking, still need to switch the bulbs. Damn Christmas Lights...
Old Nov 30, 2003
Voiceofid's Avatar
End Bringer
it's alwasy good the check the fuse, it's easy and simple
when a fuse blows on h4, it still releases some what of a current, but weak
Old Nov 30, 2003
DJPark's Avatar
DJPark is an unknown quantity at this point
The same thing happened to me last week. My passenger side Low beam went out but high beam would work. So I went and just got new bulbs for passenger and driver (so they match) and now it works fine. So your problem should just be the bulb.
I got Eurolite Xenon Plasma or something like that. It's whiter than stock bulbs which I used to have.
One problem I have is now my passenger side light is aimed up more and not so much on the road. Is there anyway I can fix this myself or do I have to go to the dealer?
Old Dec 1, 2003
fraga's Avatar
Wicked Moderatuh
Yeah, it was the bulb. (The fuse ) I took it out and you can see the wire was burnt for the low beam. So, just went back to stock, cause appearantly, I didn't have an extra bulb. Thanks guys for the replies.
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
pratik05
May 15, 2015 01:54 PM
Bigdaddy198
Apr 30, 2015 08:36 PM
