SOHC D17Ax non-VTEC - VTEC Engine Swaps Post information/questions about non-VTEC VTEC D-series engines here.
D17A1 Swapped out for a D17A (issues)
Old 10-14-2014
Metalzone's Avatar
Metalzone is an unknown quantity at this point
So my old engine (D17A1) was swapped out for a D17A with low mileage.
Now my car takes FOREVER to accelerate!
Once I get an ECU+Wiring Harness from an EX 01-05 will this solve my problem?
Old 10-14-2014
Metalzone's Avatar
Re: D17A1 Swapped out for a D17A (issues)
I'd like to add that the "D" light in the Dash is blinking.
Old 10-14-2014
usajags84's Avatar
usajags84 is an unknown quantity at this point
I think your issue may be solved on this forum
http://honda-tech.com/honda-civic-20...witch-2805426/
Old 10-14-2014
That blinking D is the transmissions equivalent of the Check Engine light for the engine.
There is a fault code related to the transmission. Read codes.
SWAG: Something got left unplugged.
Old 10-14-2014
Metalzone's Avatar
I actually got an CEL. The code reads:
P2770
Definition:
Open In Torque Converter Clutch
Solenoid Valve Circuit
Probable Causes:
1. Open or short circuit condition
2. Poor electrical connection
3. Faulty solenoid
Old 10-14-2014
So...TCC solenoid was left unplugged (or broken)?
Old 10-14-2014
Old 10-14-2014
Metalzone's Avatar
Let me get back to you in a couple minutes. Let me checked to see if it is plugged in correctly. Thanks ezone.
EDIT:
Okay so I checked and.. it seems to be broken off. I am uploading a video on youtube for you to confirm.
Old 10-15-2014
Metalzone's Avatar
Old 10-15-2014
@:12 that blue thing was supposed to be stuck on a bracket somewhere
@:45 yes it appears broken off.... But where is the wire harness connector for it?
@1:00 is the VTEC solenoid wire
Old 10-15-2014
Clean off the area so you don't knock any dirt in the hole, and replace that TCC solenoid. And its seal.
Old 10-15-2014
Metalzone's Avatar
It's part #4 correct?
http://www.hondaautomotiveparts.com/...VERTER+HOUSING
Old 10-15-2014
Looks like that should be the one.
I hate it when different departments can't use the same dang name for a given item.
Old 10-15-2014
Metalzone's Avatar
ezone you're a genius!
I'll post pictures soon.
Car's running good! NO more blinking "D".
The engine feels like my old engine with more kick! (VTEC not even wired yet).
Would you rather get the APEXI VAFC II to control the VTEC? Or should I get the EX ECU+Wiring harness? What do you recommend?
Thanks for helping out bro!!!
Old 10-15-2014
Sorry, no input on that from me. I deal with OE stock stuff.
YW.
Old 10-16-2014
Metalzone's Avatar
This thing was jacked up.
Replaced it and no more issues!
Old 10-16-2014
Yaaaaay!
Default_Slayer
Electrical DIY
12-04-2022 07:56 AM
jmdcivic
05-20-2015 09:52 PM
Jokerhogan
05-09-2015 02:52 PM
Chronic_issues
05-08-2015 05:40 PM
black2k1vtec
05-30-2013 01:51 PM
Quick Reply: D17A1 Swapped out for a D17A (issues)
