Water leaking inside car!
Old 07-15-2011
grdprx's Avatar
grdprx is an unknown quantity at this point
Exclamation Water leaking inside car!
I'm having an issue with a wet floor on the front passenger side. Dug into it this week to solve the problem. The moisture isn't chemical nor does it smell. I'm 100% sure it's water. I have the carpet pulled back, and the fabric under the dash on the firewall up. I took a 5-gallon bucket of water and poured it along the door, windshield and fender. Checked after dumping half the bucket, no water inside. Dumped the rest of the bucked, nothing. Came back 30 min later and there is a small pool of water in the corner of the rocker panel and the firewall. But there is no dripping down, it's as if the water came up through the floor! There is that hard material attached to the metal floor pan, so I'm not sure how to proceed with this issue. It's draining somewhere inside the body, and seeping into the floor pan area...
Old 07-15-2011
lazlong's Avatar
Re: Water leaking inside car!
Look for a drain tube running down the inside of the A-pillar. May have to remove the blower motor assembly to see it. Over time they will work themselves loose.
Or your heater core is leaking but, I doubt it.
Old 03-08-2019
dbailey's Avatar
dbailey is an unknown quantity at this point
Ever source that leak
Old 06-29-2019
L.red1993civicx's Avatar
L.red1993civicx is an unknown quantity at this point
Mynes leaked from the filter for the climate control fan. The windshield wiper trim was worn so it dropped from there onto the filter when it rained hard and it would puddle by the ecu
jgg204
11-11-2017 10:40 AM
kae
10-21-2012 03:30 PM
Boston77
02-13-2012 12:55 PM
Mavrick272
04-18-2010 05:07 PM
Mr_Plenty
11-03-2006 07:30 AM
Quick Reply: Water leaking inside car!
