98 civic ex electrical problems
Old 03-24-2015
mike300hayes's Avatar
mike300hayes is an unknown quantity at this point
Just bought a 98 ex. Car starts, ruins and drives perfect. ...but diagnosing the electrical issues is killing me. Any help would be appreciated. Here's the list:
Tail lights won't turn off
cluster lights won't turn off
intermittent drivers window
loud constant beep when i pull the key out of the ignition. Only goes off with the door closed.
Seems to me like way too many separate issues to all have their own separate causes. Please help! Toes of disconnecting the battery every time i stop somewhere!
Also, no CEL codes other than o2 sensor
Old 03-24-2015
Re: 98 civic ex electrical problems
Lights are all sharing the same circuit, need a wiring diagram and some testing.
Beeper is on because the lights are on.
Broken wires in the door jamb harness (probably).
Hold the switch on and swing the door open and shut. If the window stops and starts as you swing the door, it's broken wiring.
HTH
Old 03-24-2015
Everything solved except for the window. The guy who sold it to me had an aftermarket deck that he wired in wrong.
Time to try and solve the window
Old 03-24-2015
Found what looks like a 98 Civic sedan window diagram here
http://ww2.justanswer.com/uploads/EU...3_86222558.gif
CarStuff
12-06-2020 12:52 PM
bo_red
04-21-2015 12:55 PM
SSMatey
04-13-2015 06:09 PM
nickfn
11-08-2001 09:44 AM
crazydragon
11-07-2001 05:13 PM
Quick Reply: 98 civic ex electrical problems
