installed system and
Old Jun 25, 2002
Importracer's Avatar
Importracer will become famous soon enoughImportracer will become famous soon enough
welpz i finally installed my system, but now im having problems with i believe the ground, when ever i punch the gas i get a whiring like whine in my speakers, is this because of my ground? i used the one bolt on the rear seat as my ground.. any other suggestions?
Old Jun 25, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
More than likely you have engine whine....it's when the power is too close to the signal...you are getting interference. Try moving the power wire and signal wire away from each other.
Old Jun 25, 2002
whats the signal wire? the rca's? or the remote on?
Old Jun 25, 2002
mohawkboom's Avatar
the RCA's...also did your tun your pwoer down the passenger side and rca's down the right side?..also did you use good quality shielded RCA's??
Old Jun 25, 2002
WhiteRabbit's Avatar
also check your ground, a poor ground connection can contribute to alternator whine.
Old Jun 25, 2002
my rcas are by monster cable, and all my other wires are made by scocshe im using 4 guage wire for power and ground, i ran the rcas down the left side and i ran the power down the right side. i didnt have problems at first this just started happening.
Old Jun 25, 2002
pinoyVTi's Avatar
pinoyVTi is an unknown quantity at this point
sand/scratch the paint where you mounted your ground...
Old Jun 25, 2002
mohawkboom's Avatar
if that's the case..your ground has either come loose or began to corrode...
Old Jun 25, 2002
GoCivicRacerGo's Avatar
GoCivicRacerGo is an unknown quantity at this point
My 4 gauge ground came off my amp a week after i installed it, the amp would turn on and off making the music pop. This really freaked me out until i found out what was wrong. What bolt did you use? Under the seat or behind it? You could be too close to the fuel pump, just a suggestion.
Old Jun 26, 2002
i used the one thats right behind the seat, the second one..... its just one big *** blt. also i found out that my ground came loose from the connector, my system used to bump alot louder and now its really low hitting any suggestions? also some specifics with the ground please help a fellow 2k1er out, oh by the way i have 2 kenwood 10s in a parallel connection running to my briged amp at 600 watts..
oh also my amp gets hella hot is there something i should do for it? its on the trunk floor.
Old Jun 26, 2002
also how do you blow a sub and how do you know if a sub is blown ?
Old Jun 27, 2002
ttt
Old Jun 27, 2002
mohawkboom's Avatar
Okay...use either the rear seat bolt..or the seat belt bolt on the passengers side as your ground...Also..your amps getting hot because if those are DVC 4ohm subs..your running in 1 ohm mono...
Old Jun 29, 2002
WhiteCivic's Avatar
WhiteCivic is an unknown quantity at this point
To check to see if a sub is blown or ANY speaker for that matter.....use both hands to hold the speaker and GENTLY push down on the cone with your thumbs..get your head down there real close...if you hear a scratching sound or feel something rubbing and making a scratching sound...its blown. Or you could get out a volt meter too...I just prefer the old fashion thumb trick....lot easier than digging thru the tool box to find my meter
jtdunn4life
Oct 27, 2015 03:33 AM
jru27
Jun 19, 2015 03:51 PM
Youshoe
May 22, 2015 09:36 PM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
supercivic01
South
Nov 30, 2001 11:27 AM
