Simple Question
Re: Simple Question
i believe there is a relay that gets power from the headlight circuit. just wire it up to a constant power source, or something that's switched by the ignition, like the radio. i'll probably be doing this when i install mine.
I wil fix vBPlaza today
Re: Simple Question
Re: Simple Question
30A relay $1.50
http://www.partsexpress.com/pe/showd...number=330-073
30A fuse holder $1.25 (these are really good quality. i have 4 of them on my HID harness. HID's in the headlights and the fogs.)
http://www.partsexpress.com/pe/showd...number=070-675
the wire is 10ga and it's really small,fine wire strands. really flexible. it's audio cable quality.
relay socket $1.75
http://www.partsexpress.com/pe/showd...number=330-075
Re: Simple Question
I'm basically in love with partsexpress.com The pricing is really good and they carry a lot of other stuff too aside from just parts. I ordered two MTX loudspeakers for my guitar from them!
Re: Simple Question
You dont even need a relay. Powersource (battery or fuse box) with inline fuse, to switch, ground from switch, power from switch to foglight harness. I think I am using a 20 or 25 amp fuse in mine, but depending on what year car you have, the bulbs and therefore the current is going to be different.
Re: Simple Question
Re: Simple Question
So you're probably better off running a relay just to be on the safe side. It's like $1.50 and you're good up to 30 amps. Sometimes up to 40 depending on the kind you get.
Re: Simple Question
yeah ur payin dollar fifty but then you got shipping thats gotta bring them to the close cost similar but different .... honestly eitha way u look at it seems to cost close to the same...ur call though
Re: Simple Question
pretty much. after burning up so many switches in the past, i'd rather be safe than sorry. i haven't had a single switch go bad on me since i've been using relays.
Re: Simple Question
Re: Simple Question
Re: Simple Question
on my oem fogs, i just went behind the switch and cut the wire that got hot only when headlights were on and connected it to the 12v socket power. so i can use em whenever the ACC is active. here is with parking lights, but they can stay on whenever the key is in.
baconomics
Aug 26, 2015 07:47 AM
martinsmartin
Aug 15, 2015 07:34 PM
brady15
Aug 8, 2015 08:16 PM
BootyDo
Jul 7, 2015 06:06 AM
