To many tweeters?
Old Apr 18, 2007
hotrodcivic2004's Avatar
my civic has no boost
Cool To many tweeters?
Hey guys. I looked around the site but couldnt get a difinitive answer on this one. I have the an 02 ex. Recently i've upgraded my stock system with 4 ways all around. should i simply take out the stock tweeters to provide a better balance of sound? it sounds good, but just a little to much high level if you ask me. thoughts?
Old Apr 18, 2007
54321r's Avatar
54321r will become famous soon enough54321r will become famous soon enough
Re: To many tweeters?
i dont think its too much my friend has another pair more then u want to do and i think that is too much. he has a custom fitting on both sides above the backseat for 2more componets and it is rediculous and just painfully loud most of the time
Old Apr 18, 2007
i was just thinking to pull out the tweeter pods in the front pillars and put just....normal, empty sails in there.
Old Apr 18, 2007
NSRCivicRacer's Avatar
NSRCivicRacer is an unknown quantity at this point
if you do pull them throw me a price and ill take em off your hands
Old Apr 18, 2007
Intercooler's Avatar
Intercooler is an unknown quantity at this point
I have a pair in the sails and my kicks. I also run Silk domes which are natural sounding. Did you try adjusting the X-overs?
Old Apr 19, 2007
JMUCivic03's Avatar
JMUCivic03 is an unknown quantity at this point
Out of curiousity, what do you have the extra tweeters hooked up to? Your head unit? Along with your 4 way speakers? If you just have everything jerry rigged together and not properly amped and x-over'd the you might run into some problems. Which 4 ways did you purchase? I havnt seen many on the market with the exception of the ones pioneer puts out, along with their rediculous 5 ways. You also have to keep in mind that <usually> the more drivers on a speaker and typically the more expensive the speaker, the more it is supposed to be used in an amplified system along with proper low end reenforcement (AKA mid basses and subwoofers). In other words 4 ways and 5 way speakers are not going to put out rich low/mid frequencies and are primarily used to re-enforce the higher end of the spectrum.
Its all up to you, you could leave the stock tweeters in if you like, you should just make sure everything is wired correctly. You DONT want everything just plugged into your head units internal amplifier, which is most likely only meant to be run at 4 ohms nominally. You also have to make sure everything is x-over properly (AKA make sure all the lows are going to where the lows should be, and the highs are going to where the highs should be). If everything is good, just adjust the equalizer on your headunit and take out some of the treble/high frequencies.
Old Apr 19, 2007
phuviano's Avatar
Slowest 7thgen in the GTA
If you find the highs are too much for you, and don't want the tweeters. Don't bother putting empty sails in there. I think the car looks better with speakers there. Plus you have to spend the extra money to buy the sails.
Just simply disconnect the factory tweeters. Its just one wire. Its connected to a harness, and you just unclip it. It takes virtually 2 seconds to do it. If you can take your door panel a part, you'll have no problems doing this. I'm currently doing this in my ride. However, my project is a work in progess right now. I'm hoping to finish my stuff today. Thank god for a day off work, woohoo.
Old Apr 19, 2007
lxcivic2k1's Avatar
I have a question, where did you find 4-ways for the front. Most I've seen is 3-way for the 6-1/2, cause thats what I have, then 4-way in the rear.
Also please don't tell me everything is sony.....
Old Apr 19, 2007
everything is sony. they are sony 6 1/2" 4 ways
Old Apr 19, 2007
actually, i put in a cd and it sounded great. i've been using my ipod...i guess my ipod is just a POS.
Old Apr 19, 2007
mani_is_kool's Avatar
mani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nice
The Ipod doest sound better than a CD for some reason ... I had the same problem ...to me it sounded like my brand new Kenwood components had been Punctured like a ping pong ball or something ... i took off the ipod and voila !!!! ... FOr some reason the IPOD equalizer settings dont go well with our factory or aftrmrkt headunits...
Old Apr 20, 2007
JMUCivic03's Avatar
I think think it is more likely the head unit that is to blame for the poor auxilary sound. Just to warn you, sony speakers are notorious for frying and having multiple other problems. Hell my first sub system way back when was a sony package....amp/subs and they fried with the resomended amp that came with it, at moderate to low settings. I will say, the amp has lasted though, I still use it as an "in-between amp". There headunits are also said to have lots of bugs...screens cut in and out, internal amps overheat, processor issues, interference, etc.
Old Apr 20, 2007
JMUCivic03's Avatar
That really all depends on the head unit. Plenty of head units out there today have integrated Ipod compatibility that allows you to control just how much the sound is processed through the head units. I know Ipods sound great with every pioneer deck that Ive ever used one on, they sound great with the alpines Ive tried them on as well. This is all having them directly connected to the head units of course, not through one of those connect-through-radio signal type deals. Those are just asking for crappy sound and interference.
Old Apr 20, 2007
its an older ipod as well. my buddy has the same head unit and uses his new ipod nano and it sounds awesome. i may ultimatley get a zune or new ipod. thanks though guys.
Old Apr 23, 2007
AequitasVeritas's Avatar
AequitasVeritas is an unknown quantity at this point
hook tweeters up
listen
unhook tweeters
listen
use which ever one sounds the best
Old Apr 23, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
^ That's so simple it just might work.
ZoSoIV
Sep 17, 2015 07:17 PM
Jeffdp
Aug 5, 2015 11:38 AM
STang57
Aug 2, 2002 07:59 PM
TroyA
Jul 7, 2002 10:18 PM
