how to (tdc) my cam
Rep Power: 0 how to (tdc) my cam
Ok I'm a novice mechanic and I was changing a head gasket, I heard u didn't have to top dead center the cam if ur just changing the gasket or remove the dissy. Turns out I had a chipped valve so I started to remove rocker arm assembly. I accidentally turned the cam. So my question is now that the cam is turned how do to sync my cam and engine to top dead center
Received 1,148 Likes
Rep Power: 485 Re: how to (tdc) my cam
If you're taking off the timing belt, always set to TDC. Better safe than sorry.
With the head off, set the head to TDC and set the crank to TDC on cylinder 1.
Rep Power: 0 Re: how to (tdc) my cam
Thanks I'll do that today and I'll head out to AutoZone and get one. My father is a mechanic but don't have the time to help 14 years exp.
09-26-2023 06:44 PM
Roman Rembacz
07-16-2015 12:30 PM
muttleytm
07-14-2015 05:31 PM
