1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Power issues
Old Oct 12, 2015
nadon's Avatar
nadon is an unknown quantity at this point
Power issues
I have a 93 Civic that I just traded some items for. New parts on the front end and runs good for 230k on it. Issue it seems to have is as follows, when it is hot out you can drive it for about 20-40min and then it will start to act up, such as the power gauges start to mis-read, it seems as if it wants to stop and at times will. Lights flicker and so on. So you let it sit and cool off and it then runs fine for about the same time.
When it is cold out there are not issues, runs fine all the time. I have taken the battery out and had it test and it tested fine, not to say it would need to be hot to test. I was thinking the Alternator but was unsure. Anybody got any ideas of things to try please let me know.
Old Oct 12, 2015
Mad Dog Tannen's Avatar
Re: Power issues
Check/tighten/clean all of your engine/battery/starter wires. It sounds like maybe a intermittent connection somewhere.
Check engine light?
Old Oct 12, 2015
nadon's Avatar
Re: Power issues
I have cleaned all the cables with a wire brush as I though the same thing. The check engine light, oil light and the others blink on and off. I was going to go get the Alternator checked but if it is not warm enough it may not do any good. Is there a coil pack on these, could that be getting to warm?
Old Oct 12, 2015
Re: Power issues
Sounds like a bad ignition switch....
WTF is "the power gauges"?
Old Oct 12, 2015
nadon's Avatar
Re: Power issues
By power gauges I meant the seat belt light, the battery light, the check engine light. Sorry to state it wrong, they start to blink on and off.
Old Oct 12, 2015
Re: Power issues
When it acts up, Rock the ignition key back and forth slowly and all those lights will blink as the ignition switch makes and loses contact....
If you can get it to act up this way, it's a bad switch.
Old Oct 12, 2015
nadon's Avatar
Re: Power issues
Thanks will give it a try.
Old Oct 12, 2015
Re: Power issues
That happened in my Volvo, I had to start the car then gently rock the key back to get the lights to come on lol.
h4ldol
Jun 3, 2015 03:26 PM
FlexEX
Nov 21, 2001 09:51 PM
808specifxz
Nov 17, 2001 10:39 PM
WhosYoDadday85
Nov 3, 2001 11:23 PM
Elusiv1
Oct 2, 2001 05:44 PM
