Help! Keyless entry and dome light.
Rep Power: 0 Help! Keyless entry and dome light.
Hi!
I recently bought a 1998 Civic lx and found out the power locks doesn't work. I did some research and discovered that the keyless entry and the dome light "when opening the door" system is in the stock stereo. The car has an aftermarket one. I read that to make the keyless entry work, I have to get a stock stereo. I don't really care about the keyless, but I do care about the power lock and dome light. I there any easy way to fix it?
Note: I don't know much about cars, so any help is welcome
Thanks in advance
Thanks in advance
Re: Help! Keyless entry and dome light.
This is simply power locks don't work?
Look in the door jamb harness for broken wires at the door connector.
You may need a wiring diagram specific to your car to figure out how to diagnose locks and lighting.
Rep Power: 0 Re: Help! Keyless entry and dome light.
I thought the problem with the power locks was because of the keyless entry.
Having power locks does not automatically mean it was equipped with keyless entry too.
Is your car equipped with keyless entry?
Have you removed the non-factory radio to investigate connectors or control units that may still be in the dash? Radio may be connected to a gray connector, but are there 2 more green connectors?
Is there a connector that would have been for the keyless and dome light controls?
It looks like you are not in the continental USA. Was your car originally sold in the USA? Canada? Some other country?
Yes, there are 2 green connectors, one is smaller than the other
I bought it and it had the aftermarket radio already.
I bought it in Puerto Rico
I'm looking at wiring diagrams for USA cars. If I'm reading this correctly, it looks like the power locks should be able to operate independently without the keyless control unit in place.
There is a power lock control unit in the drivers door. The keyless system would send commands to the power lock control unit, but does not operate the locks directly.
Broken wires in the drivers door jamb is a very common problem. I'd look there first.
For the dome lights issue, I think you can use jumpers to connect some of the circuits in the green plugs to get them to work again. I know this info is on the internet. It may be in this site somewhere too.
But was the car built specifically to be sold there, or was it originally sold in another country and then imported?
I'm almost certain that is was originally sold here.
So you don't know if the power locks or dome lights ever worked properly after the non-factory radio was installed?
Nope
Nope
it worked but the "sensor" or whatever that it's called, is not making contact with the door. If I push it with my hand, it will turn OFF the light
It's just a plunger style switch in the jamb. Once in a while the plunger (button) breaks, but usually it's something else causing the door to not make sufficient movement of the plunger.
Check: Door striker adjustment, or maybe securing a 'pad' of some sort in the right location on the inside of the door to push on the switch? Some doors had a small round rubber bumper to contact the switch, maybe it is missing?
Compare to the other door, see how it is set up.
I only have access to diagrams for US cars, and I have no way of knowing if your car matches exactly.
It's probably a US car. I definetely doubt the previous owner bought it outside of the US.
Sounds like you made good progress!
Thanks!
I noticed that the door has a dent that the passenger door doesn't have(The driver side door is the one that doesn't work). I taped a piece of plastic on the "button" and it's now working fine, but i'm skeptical because if the piece of plastic moves or the tape gives out, the dome light will be ON and it will drain the battery. Any tips on that?
Sorry, but what's a "Door striker adjustment" i'm a total noob lol.
Thanks!
Once in a while I see cars where the seat belt tongue has dangled and the door was slammed on it denting the door or body.
Remove the door panel and get inside the door to poke/pry the dent out??
bolt-on-bandito
Electrical
32
01-15-2020 03:25 PM
h4ldol
04-24-2017 08:16 PM
Ziggy1999
10-15-2015 07:56 PM
PunX
09-23-2015 10:45 PM
MichaelLW
09-14-2015 07:15 AM
