Sponsored by:
Sponsored by: DashLynx
Licence plate lights not turning on...
Old 09-05-2008
Jackios's Avatar
Jackios is an unknown quantity at this point
I have problem with my licence plate lights not turning on. I bought a set of LEDs for my plate but when I went to change the bulbs, I noticed that neither stock bulbs were working. LEDs did not turn on... tried it on my friends civic and it's working fine. Had a feeling it was either the socket or the fuse. I had a look at my manual and checked the fuse for the licence plate light, the closes fuse I got to was the Small Light fuse located at #2 and the fuse wasn't blown. Sockets were fine. Anyone come across this problem or have any suggestions please reply! It's a pain to bring my car to Honda and have them do service on it and pay $50 an hour. lol! Thanks in advance!
05 Civic Si Sedan (CAN)
Jackios is offline
Old 09-05-2008
CraigW's Avatar
Re: Licence plate lights not turning on...
Are your taillights located in the trunk section working ?? (assuming you have those on your model)
You could have a broken wire in the harness that flexes with the opening/closing of the trunk.
I had the wire break at a crimp terminal that had 3 wires leading to 1 wire going into trunk lid loom powering licence plate and inner tail lights bulbs.
The wire color should be RED/YEL.
CraigW is offline
Old 09-09-2008
Jackios's Avatar
Thanks CraigW for your reply. Yes my taillights are working. I tried getting into the wires and found the red/yellow wire but haven't seen any breaks. A buddy of mine is going to have a look at it some time this week and I'll let you know what he comes up with.
Jackios is offline
Old 09-09-2008
HonCiv02's Avatar
HonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond repute
it sounds like a fuse or wiring problem; have you checked all the possible fuses that it could be?
HonCiv02 is offline
Old 09-09-2008
CraigW's Avatar
If the taillights are working the fuse is o.k., If the inner taillights (on the trunk) are working the RED/YEL wire going to the trunks lamps is o.k.
CraigW is offline
Old 09-10-2008
Jackios's Avatar
Looks like the inner tail lights (ones on the trunk) weren't turning on.
Checked every possible fuse the license plate lights would be under and they were all working fine. No problem with the ground.
Quoting what you were saying CraigW: "You could have a broken wire in the harness that flexes with the opening/closing of the trunk."
That is exactly where the problem was. Seems like this is a common problem from what my buddy told me (car technician). The opening and closing of the trunk puts stress on the wires causing it to snap.
Took a couple pictures after it was fixed:
http://i240.photobucket.com/albums/f...9-10_19-51.jpg
http://i240.photobucket.com/albums/f...9-10_19-52.jpg
Thanks all to who replied. Hope this helps.
Jackios is offline
Old 09-11-2008
CraigW's Avatar
My 05 broke near the crimp junction that has 2-3 wires going into the single wire that goes to the lamps.
I first noticed it when unlocking the car.
Thanks for posting the diagnosis !!
CraigW is offline
Old 06-14-2010
Charzeron's Avatar
Charzeron is an unknown quantity at this point
Thanks for the info. After checking the bulbs and fuses and finding them fine, I wasn't sure where to start poking around for the wires and I came across this post. It just happened that the break was right at where the push-mount cable tie was. The electrical tape around the cable conduit was already a bit frayed from the cable tie so it was easy to peel off in that area. New pics are attached below since the old posted pics don't seem to work anymore.
I pulled one of the wires out to show where the break is in relation to the cable tie. The other two pics just show the bundle of wires which need to be recrimped or soldered together. The crimp is covered with electrical tape from the factory. Oh, and this was in a 2005 Civic sedan.
ID:	78508   Click image for larger version
ID:	78509   Click image for larger version
Charzeron is offline
Old 06-15-2010
CraigW's Avatar
I recently found a TSB on this problem.
CraigW is offline
trellex
05-24-2015 04:39 PM
jimmyfloyd
05-20-2015 07:06 PM
crowtoo
05-11-2015 06:50 PM
blackbullet
12-01-2001 03:44 PM
wawacito
11-05-2001 03:32 PM
Quick Reply: Licence plate lights not turning on...
