Transmission Filter Retrofit
Old 03-04-2014
chuffsy's Avatar
chuffsy is an unknown quantity at this point
My 2010 civic has 19k miles and I am thinking of renewing the oil and filter in the next coming months. I have previously owned a 2000 Odyssey on which I installed a transmission cooler and Magnefine filter (bypassing the stock one ) . Has anyone here retrofitted with a Magnefine filter without any functional issues? It seems to get to the stock filter the airbox has to be removed and should I go with a retrofit I think I would reroute to make it more accessible for servicing .Comments?
Old 03-04-2014
Re: Transmission Filter Retrofit
Not sure if this will help you any, but here's a pic of the backside of the drivetrain, out of the car.
You can see where the OE inline trans filter is.
Here's a pic with the engine out of the way
There isn't any cooler lines at the radiator to tap into, they are all on the trans itself. You'd probably need to use these pipes at the original filter, use long hoses and make a remote mount.
The cooler is mounted on the front of the trans.
FWIW, at the shop I work in, we do not replace that filter as part of any regular service.
Old 03-05-2014
CraigW's Avatar
If anything just change the original filter.... but at 19k I would not expect much has accumulated. Time and low mileage are more of an issue imo.
Old 03-05-2014
cricket's Avatar
cricket is an unknown quantity at this point
What is connected to the thermostat housing on both sides
Old 03-05-2014
You mean the 1/2" coolant hose? If it's the one I'm thinking of, it runs to the ATF cooler/warmer bolted to the trans.
Old 03-06-2014
chuffsy's Avatar
That filter sure is hidden away! Thanks for the pics ! I peeked again into the engine and scratched my head as to where I would route hoses for a service convenience. Space is so tight! For now I think I will just do a fluid change in the near future ( understand from here that the new fluid DW is current) then muster up the courage for a filter change next year sometime. It seems the filter change would just be a conservative action on my part.
Old 03-06-2014
CraigW's Avatar
Very tight in the bay for sure.
Z1 went fast, DW1 is fine, my 2010 has had a couple of doses.
Old 06-29-2020
chuckiecheese's Avatar
chuckiecheese is an unknown quantity at this point
Question Re: Transmission Filter Retrofit
I also am about to do a trans fluid change on my 2010 EX-L and definitely want to change the filter.
I am under the impression that there is also a "strainer" inside of the trans.
Has anyone ever changed one of those as a maintenance item?
Old 06-29-2020
No, only during a rebuild. . You'd have to pull the trans out of the car and disassemble the case in order to find it. .
Old 06-30-2020
Thanks! you just saved me some grief!
LorenzoC0395
07-14-2015 08:46 PM
f575gtc
Transmission
07-13-2015 09:16 PM
mistermenphis22
07-13-2015 04:43 PM
07-12-2015 11:54 AM
CivicsClass101
07-09-2015 11:14 AM
Quick Reply: Transmission Filter Retrofit
