Something Crazy
Well I fixed it now, my dumb ***, when I put the wire for the horn threw the hole in the firewall i guess when I was pushing it threw I slpit the wire to my A/C and Heat in half so I had to get down there and wire it back up. It sucked !
If you look under the passenger side dash in the floor board almost. Its got about 40 wires in it, then there is a rubber gromet. I didnt know there was a hole behind the brake pedal I might have to rewire everything if itll look better, its kinda all bunched up right now in the same spot.
Ah ha.. i'll have to take a look at that. .. .
underneath the brake pedal, kinda inbetween the brake pedal and the clutch, you will see like a plastic plug, pop that out and you will see a hole in the firewall.
There is a spot to the left to feed the wires through, so you can put the plastic plug back on.
mac25
Aug 21, 2015 11:14 PM
adamdrives
15
Aug 8, 2015 08:53 PM
suburbanite
Jul 17, 2015 03:05 PM
