cool diy /w underbody neons. even better if you have alarm or keyless entry.
Old Jun 5, 2003
Chrissy's Avatar
Chrissy is an unknown quantity at this point
got some neons today for my civic and installed them and instead of hooking them up directly to the battery and the neon's on and off switch, i did something different.
i hooked them in parellel up to the left parking light and voila... you have your neons flash each time you lock/unlock your door and plus have them instantly turn on when you switch the headlights on. no more damn switches. i made a switch that bypasses the neons just in case i cant drive while neons are on (e.g. some states). now to prevent the fuse from blowing, replace with a 15 amp fuse (300 watts).
Old Jun 5, 2003
civicvtec1ps's Avatar
Search and Learn
and wheres pics!!!
Old Jun 5, 2003
Chrissy's Avatar
Originally posted by civicvtec1ps
and wheres pics!!!
will be there tomorrow when it is bright outside... fairly easy diy to do. from a skill level 1-10, i rate it as a 1, like the throttle body heater bypass.
Old Jun 6, 2003
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
wow... chrissy this sounds awesome... can you PM me with all the instructions you did... like in detail so i can do the same.... well... actually i'm installing red... so i just need info on the bypass switch and to blink them when unlocking and locking my car.... thanks
Old Jun 6, 2003
Chrissy's Avatar
1st diy without pics
things needed:
flashlight
some speaker wire
flat head screw driver
wire cutter/stripper
soldering iron
radioshack lil switch (any small one should do)
electric tape
1. turn you car on, turn steering wheel all the way over to the left
2. on the front right wheel, pop the little fastener out with you flat head screw driver.
3. while spreading the wheelwell and the bumper apart, reach your hand in and locate the right parking light and unplug it
4. 1st hardest part: with the parking light wire unplugged and in your hand, you will see an outer insulator wrapped around an insulated red and black wire. (REMEMBER RED IS POSITIVE, BLACK IS NEGATIVE!) unwrap the insulator and until the red and black wires are exposed, put a little cut in both with the wire cutter on both of them to expose the metal wire inside.
5. once you get the insulation off a little exposing the bare wire, you can solder like 2 feet of speaker wire to both of them. (dont forget which is negative and positive)
6. guide the speaker wire to the + and - to the transformer.
7. strip the end of the positive wire, connect it to one part of the switch and connect the other side of the switch to the transformer wire leading to the transformer
*the switch is to turn off the neons just in case you cant have them on while driving. it will be located under the hood.
8. strip the end of the negative wire, connect to the transformer directly.
9. test circuit out. if working , solder all joints and wrap with electric tape if not working, inspect the joints and/or make sure the positive and negative arent touching. (short)
10. whalla, now you have keyless entry activated neons. and when you turn on your headlights, they should turn on automatically.
Old Jun 6, 2003
guamcivic2k1's Avatar
YoUnG N SuXsExFul
wow that sounds awesome! good job! just wnat to see pics or maybe even a video! maybe ill try it out when i get enough money for neons..
Old Dec 20, 2003
7thGenerasianCivic's Avatar
Where are the pix Chrissy? LOL
Old Dec 20, 2003
NeonImpact's Avatar
Forum Sponsor
omg, so old, locked!
Ziggy1999
Oct 15, 2015 07:56 PM
henrytn
Aug 11, 2015 10:01 PM
Roo
Ottawa
16
Jul 9, 2004 06:58 PM
Manofsteel
Dec 27, 2002 03:05 PM
Blingin01Civic
17
May 9, 2002 10:47 PM
