Spark Plugs
Old Apr 28, 2003
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Spark Plugs
Hey....I need to change my spark plugs this afternoon. But I wont have access to my owners manual at that time. So can anyone tell me the socket size to remove our plugs? And anythin i need to know about the whole "procedure"? I've seen it done on B series cars...but our cars are slightly different...just wanna check. Any help would be great.
Old Apr 28, 2003
robbclark1's Avatar
Retired suspension supermod.
5/8" spark plug remover and a long extension.
Old Apr 28, 2003
SpdRcrChk's Avatar
BOOST JUNKY
Thanks Robb. ur da best.
Old Apr 28, 2003
robbclark1's Avatar
yep, no problemo
Old Apr 28, 2003
flotsamm's Avatar
Spark Plug Gap:
0.04 in (1.1 mm)
Old Apr 28, 2003
SQCivic's Avatar
SQCivic is an unknown quantity at this point
I don't understand the gap post. Is changing the plugs just a matter of removing the old and popping in the new? Sorry for the newbie question.
Old Apr 28, 2003
Bogus1's Avatar
Bogus1 is an unknown quantity at this point
Basicly thats what it is but when u buy new plugs they come pre-gapped. Remember there could be another car that can fit the same spark plug as your but has a different gap. Also the gap may change when the plug is shipped due to tossing of the container.
Old Apr 28, 2003
SQCivic's Avatar
so we should check the gap and adjust it somehow?
Old Apr 28, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
ALWAYS check the gap when installing new spark plugs, in fact i check mine when i change the oil, iv only had to re-gap one of them
Old Apr 28, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
also they are to be torqued to 13 ft lbs...i think thats right...
Old Apr 28, 2003
Bellz's Avatar
I did a quickie DIY on this last year. Check it out HERE if you need any pointers.
Since the subject of torqueing the plugs came up, I'm going to paste a paragraph in here with the proper information for putting them in w/o a torque wrench (which most of us probably don't have).
9. Now this is important!! Don't tighten it with the socket wrench until you've snugged it with your hand. Let me explain. You plac the plug in the socket, attached the extension and with your fingers, gently place it into the hole and turn clockwise with your fingers. If it tries to cross thread, you'll notice it immediately. Remember, these plugs take several rotations to seat all the way down, so if it cross-threads, you'll know quickly. After it snugs, you can then tighten it with the socket wrench. The back of the Denso package shows that a non-tapered plug like the IK20 should be tightened 1/4 to 1/2 turn when you do the final tightening. This will properly seal the metal gasket. Do NOT overtighten the plug, as you may strip the threads.
SimpleUser
Apr 24, 2021 02:54 AM
Tommy Cohen
Jul 22, 2015 07:54 PM
1khilari
Jul 9, 2015 08:12 PM
jzhartman
Jul 9, 2015 04:56 PM
CivicsClass101
Jul 9, 2015 11:14 AM
