Brakes and rotors
Old Mar 16, 2003
Gizmo's Avatar
Gizmo is an unknown quantity at this point
Brakes and rotors
I am looking for brakes that show less dust and are a little better at stopping power than the oem brake pads. I heard that the AEM pads are pretty good. What about rotors? Anyone have suggestions on rotors that would go good with the AEM pads.
Old Mar 16, 2003
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
My AEM Rotor Brake Kit is pretty good for stopping my car. as for dust wise, i'm not sure, i know that the wilwood brake kit gives you lots brake dust...but as for the power our engine is producing, stock rotor is good enough, unless of course u do a swap or turbocharged
Name:	aem brake kit.jpg
Old Mar 17, 2003
dacivic's Avatar
dacivic is an unknown quantity at this point
I agree with CivicVTec. You really don't need to change brake rotors except for look. Basic brake pads chaning (AEM one) should be good enough for everyday driving. Dust wise AEM pads give off light grey dust instead of black, so less visble. If you really want better brake rotor try BREMBO Blanks. I had them on my last car(6gen civic) and worked pretty well.
Old Apr 11, 2003
CivicEnvy2001's Avatar
CivicEnvy2001 is an unknown quantity at this point
brembo makes good rotors
Old Apr 13, 2003
K@mik@ze's Avatar
K@mik@ze is an unknown quantity at this point
I have read numerous articles which state that drilled rotors have a tendency to crack, so I'm looking for some fairly decent slotted rotors. Anyone know of any? My 2003 Civic HX with just under 15,000 miles has warped rotors, 'cause I drive the backroads at over 100mph on a daily basis.
Old Apr 13, 2003
K@mik@ze's Avatar
Also....which pads are known to dissipate heat the best?
Old Apr 14, 2003
sovereign82's Avatar
sovereign82 is an unknown quantity at this point
I got Brembo Rotors, NOT drilled NOT slotted...IMHO the drilling and slotting on our cars has no effect....plus I got BOTH for $72 shipped instead of $150 for drilled and slotted....
Old Apr 14, 2003
K@mik@ze's Avatar
I tend to disagree with you, because slotting and drilling drastically helps to dissipate heat
, which causes rotor warpage. I began to notice rotor warpage at less than 12,000mi. Given, I do a lot of high-speed (90+mph) and mountainous driving. Let me know how your regular Brembo's hold up, and what kind of driving habits you have (i.e. how fast, how hard braking, etc...) and I may consider them.
Old Apr 14, 2003
HondaLuver's Avatar
Its a celebration bitches!
the discs don't even need to be slotted or drilled, you can get some good brake kits like "The Brake Man", which have really good kits and why is AEM putting out new kits where its not drilled, because its better, less cracking discs.
it doesn't mean its better.. if it is drilled...
Old Apr 14, 2003
dezod's Avatar
7thgen Power Maker
FYI
I HAVE PRO STOP ROTORS (BY POWER SLOT) AND THEY ARE GOOD! THEY LOOK NICE, ESP W/ RIMS, THEY ARE SLOTTED AND DIMPLED. THEY ARE NOT DRILLED! DRILLING THE ROTOR COMPROMISES THE INTEGRITY OF THE ROTOR, WITH THE POTENTIAL OF CRACKING. NOT EVEN BREMBO GUARANTEES THAT THEIR DRILLED WILL NOT CRACK. I GOT MINE FOR A LITTLE MORE STOPPING POWER + BETTER LOOK THAN STOCK RUSTED ONES BEHIND MY RIMS. TRUE, SLOTTED AND DRILLED DISIPATES HEAT BETTER THAN ANY OTHER BUT IT CREATES LESS BRAKING SURFACE AREA.
BE AWARE, THAT BREMBO DOES NOT MAKE A SPORT ROTOR THAT IS BOTH DRILLED AND SLOTTED. THE GRAN TURISMO KIT IS THE ONLY ONE BREMBO MAKES THAT IS BOTH. THE SPORT ROTORS ONLY COME IN SLOTTED OR DRILLED. THEY DO NOT COME INDIVIDUALLY BOXED EITHER. IF YOU PRUCHASED A BEMBO ROTOR THAT IS DRILLED & SLOTTED, IT WAS A BREMBO BLANK BOUGHT AND MODIFIED BY A THRID PARTY AND WAS NOT FULLY FINISHED AS FAR AS BREMBO'S STAND POINT. THEY ARE NOT TRUE BREMBOS. THEY ARE JUST THE CASTING. ALL OF THEIR TRUE ROTORS ARE GOLD CADMIUM PLATED TO PREVENT RUST. POWER SLOT ARE SILVER CADMIUM PLATED AND ARE SLOTTED, UNLESS YOU GET THE PRO STOP WITH DIMPLES AND SLOTS.
PADS: I RECOMMEND AEM, AXXIS OR GREEN STUFF.....ALL VERY GOOD!
Old May 3, 2003
LuZi0n's Avatar
LuZi0n is an unknown quantity at this point
good info djlutchi...im looking into your powerslot rotors
Old May 3, 2003
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
i recommend ebc slotted rotors and ebc brakes. i havent tried greenstuff, but redstuff is great. the bite is close to stock but the heat dissapaction makes for less dust less chance of rotor warp.
Old May 3, 2003
Zzyzx's Avatar
Autocross Junky
If you plan do do Hard driving, I wouldnt recomend AEM pads. What i mean about hard driving is TRACK DAYS (Road race not drag) where Brake temps can reach 650-750 Degrees F. Im not saying that AEM pads aren't good, its just that I havnt found a site that will tell me what temps they are stable till. However, EBC brake pads, both RED stuff and the GReen stuff would both be sufficent. the Red stuff is a harder/Higher temp pad sutible for track days and Hard street driving on a Heavy car. their only draback is that they need to be warmed up to work their best. They are stable at over 750 degrees. The Green stuff is what I would recomend for us. It has Excelent initial bite, and a MUCH higher Coefficient of Friction then both The Red stuff and STOCK. The Green stuff is stable at 650 Degrees.
Old May 3, 2003
1jazzyciv's Avatar
1jazzyciv is an unknown quantity at this point
For my 2 cents... I have the brembo slotted rotors and Axxis pads - I would have rather gone with the Green Stufs but the deal was a good one - I surely recommend the slotted w/ Green Stuff. They have more bite than factory - look greta with rims and are not radically expensive.
Jazzy
Old May 3, 2003
LuZi0n's Avatar
which one creates the lest brake dust b/c i have white wheels and those mugs already dirty up quick as it is
Old May 3, 2003
i believe redstuff are suited for around 1000 degrees F
Old May 3, 2003
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
how much r the greenstuff pads, and how much r the redstuff pads, i know the aem ones r like $40 for two, also how much does it cost to slice ur rodors at the dealer?
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
muniorbust
33
Aug 31, 2015 08:59 PM
bsmiley
Aug 13, 2015 10:32 PM
Strycker
Aug 2, 2015 08:40 PM
General 7th Gen
Jul 9, 2015 10:17 PM
