goldlines with no camber kit
hey who here has goldlines with no camber kit??
cuz i'm getting my goldlines put on saturday but I really don't want to get a camber if I don't need it so I was checkin to see how some people with goldlines are doing..are your tires showing like obvious wear...
All I'm probably going to get is an alignment..
Post Whore General
I use to have H&R springs with no camber kit, and you couldn't tell the camber was off. Never really wore the tires that bad at all. Not till I got coilover and did a 4 inch drop did my tires wear really fast.
Quote
[hr]Get the alignment first. The technician there should be able to give you a suggestion of whether you are close to stock tolerance settings or not. [hr]
i forget who said it but someone did earlier, more than 2"... yes, less than 2"... no. Most people suggest if your going to drop your car (with stock struts) do it NO MORE than 2" but preferably 1.75". that way, you get no uneven wear hence no need for camber kit.
like i said before.. you will need a camber kit. by eyeing it you can see that the rear tires are about -2 to -3 degrees. however, you won't need a camber kit in the front. when i got my alignment, my front tires were at -1 degrees each but a toe in adjustment will offset the negative camber.
Show me your titties, I'M RICK JAMES BITCH!!!
Quote
[hr]Originally posted by: zzzzzzzzzv
get your rear camber kit from hondawerx.com[hr]
Dave Brabant
20
Oct 6, 2015 12:44 AM
Hutch1051
Sep 29, 2015 09:20 AM
