goldlines with no camber kit
Old Feb 17, 2003
DoYung's Avatar
DoYung is an unknown quantity at this point
hey who here has goldlines with no camber kit??
cuz i'm getting my goldlines put on saturday but I really don't want to get a camber if I don't need it so I was checkin to see how some people with goldlines are doing..are your tires showing like obvious wear...
All I'm probably going to get is an alignment..
Old Feb 17, 2003
Jodster's Avatar
Post Whore General
I use to have H&R springs with no camber kit, and you couldn't tell the camber was off. Never really wore the tires that bad at all. Not till I got coilover and did a 4 inch drop did my tires wear really fast.
Old Feb 17, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
more than 2" yes camber, less than 2" no camber
Old Feb 18, 2003
eXNBP's Avatar
eXNBP is an unknown quantity at this point
Get the alignment first. The technician there should be able to give you a suggestion of whether you are close to stock tolerance settings or not.
Old Feb 18, 2003
Quote
[hr]Get the alignment first. The technician there should be able to give you a suggestion of whether you are close to stock tolerance settings or not. [hr]
yea i guess that works too, hes not always right but i have to agree with him on this one
Old Feb 18, 2003
VNlilMAN's Avatar
The Standard One
get an alignment first? if the camber is off, your going to have to pay for alignment again.. why would you want to do that?
Old Feb 18, 2003
HRocket2k2's Avatar
HRocket2k2 is an unknown quantity at this point
yeah the point of the alignment is to correct the camber if you have a camber kit installed...
Old Feb 18, 2003
zzzzzzzzzv's Avatar
zzzzzzzzzv is an unknown quantity at this point
when i installed the goldlines on my car.. the rear camber was very noticably negative. you will definitely need a rear camber kit.
Old Feb 19, 2003
kraziest1's Avatar
kraziest1 is an unknown quantity at this point
are there any good places to find a camber kit? and does anyone know what the drop on the goldlines is after they settle.
Old Feb 20, 2003
zzzzzzzzzv's Avatar
bout 2 inches.. ~1 finger all around w/ 205/45/17. get your rear camber kit from hondawerx.com
Old Feb 21, 2003
kraziest1's Avatar
do you necessarily need the camber kit?
Old Feb 22, 2003
EnProceso's Avatar
i forget who said it but someone did earlier, more than 2"... yes, less than 2"... no. Most people suggest if your going to drop your car (with stock struts) do it NO MORE than 2" but preferably 1.75". that way, you get no uneven wear hence no need for camber kit.
Old Feb 23, 2003
zzzzzzzzzv's Avatar
like i said before.. you will need a camber kit. by eyeing it you can see that the rear tires are about -2 to -3 degrees. however, you won't need a camber kit in the front. when i got my alignment, my front tires were at -1 degrees each but a toe in adjustment will offset the negative camber.
Old Feb 23, 2003
dragoon's Avatar
some places offer lifetime alignment plans. maybe get one of those?
Old Feb 24, 2003
SilverStreakEX's Avatar
Show me your titties, I'M RICK JAMES BITCH!!!
SilverStreakEX is an unknown quantity at this point
Quote
[hr]Originally posted by: zzzzzzzzzv
get your rear camber kit from hondawerx.com[hr]
uhh where on their site are they selling the rear camber kit? and for how much? i was just on their site and couldnt find anything?? [IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
