i hear a poppin sound when i turn
Old Feb 7, 2003
profurious's Avatar
I Am The Chosen One
profurious is an unknown quantity at this point
i've started to notice this popping sound when i turn my car, it doesn't happen all the time, only on certain turns (sharper turns at low speed). it feels like it's coming from rite behind the fire wall on the drivers side. my car has been lowered (eibach pro kit) so i don't not if that has anything to do with it. if anyone has an idea of what this could be i would realy apreciate your input.
Old Feb 7, 2003
DizWikedCivic's Avatar
do you have coilovers or springs? this is a common problem, inspect your suspension again
Old Feb 7, 2003
2001civ's Avatar
2001civ is an unknown quantity at this point
the springs might be rubbing together, if you don't get those parts lined up just right then they rub and do that. might have to take it a part and make sure everything is lined up perfect. have someone turn your wheel and see if you can find where it is rubbing.
Old Feb 9, 2003
Weaponx12o's Avatar
it might just be the springs moving around on the perch, if it's that then you don't have to worry about it, but if its not the problem then you should get it checked. and no offense, but the prokit doesn't really lower the car, it's pretty much the same as stock springs. i'm not trying to hate on you or anything, i just really dislike the prokit [IMG]i/expressions/face-icon-small-nono.gif[/IMG]
Old Feb 10, 2003
profurious's Avatar
I Am The Chosen One
guy not hatin back but the pro kit gave me a great drop, i have no wheel gap what so ever in the rear, actualy i have reverse gap by about 1/2", and the front only has about a 1/2"gap. this is perfect for me, any lower and i couldn't get around my town. the kit lowered way more than they said it would. its gonna look even sweeter when i get my H&R trac+spacers on.
Old Feb 24, 2003
jbogden's Avatar
jbogden is an unknown quantity at this point
My gf had the same problem with her car(not lowered) on her '01 ex, I've had the problem before in other car, struts were bad causing it to sit to low and throwing off the angle on the cv joints, Does it happen more when you accelerate?have the struts/cv joints checked 1st though
Old Feb 25, 2003
MadSpeed's Avatar
MadSpeed is an unknown quantity at this point
Check the boots on your CV joints make sure they arnt leaking grease.....if they are buy some new boots and repack them with greese ASAP. Sometimes when shops do work on suspension they will mess with other things....I've had a shop slit my boots on my CV joints before so check them out. (More problems for you = more money for them)
Old Feb 25, 2003
profurious's Avatar
I Am The Chosen One
got it checked out and its the struts. gettin fixed soon, they're on back order
danace99
23
Jun 28, 2015 08:49 AM
edgenet
May 2, 2015 08:00 PM
Dorval Andre
May 1, 2015 09:37 AM
TAZZ
Dec 5, 2001 09:35 PM
supercivic01
South
Nov 30, 2001 11:27 AM
