How to Remove Console with the metal trim?
Old Jan 31, 2003
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
I want to put in a different shift ***, so I have to remove my center console, I've read the DIY on this site for removing the console, but I had the metal trim kit installed and it covers the gaps that you need to put the screwdriver in, I was wodering if anyone else has been able to do it without F'Ing anything up, or if anyone has any suggestions on replacing the shift not without removing the console, Thanks
-Mark
Old Jan 31, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
If all you're doing is changing the ****, just push down on the boot collar until it pops off. Then unscrew the ****. The console only has to come out if you swap the boot too.
Old Jan 31, 2003
Renamazazo's Avatar
But I can't get the collar off of the boot without taking off the console right? Cause The shift *** I have won't work with that collar.
-Mark
Old Jan 31, 2003
Jap-Euro Fusion
If the collar has to come off, then the console does have to come up, but you still have to unclip and remove the **** to do so. That still leaves.... how are you going to attach the bare end of the boot to the bottom of the ****?
There's a console DIY somewhere... if you've got an 03, then I dunno... it's probably a little different now that there's an armrest storage.
Old Jan 31, 2003
4bangin's Avatar
i dont think there is any shift **** out there that will reattach to the boot. i just let mine fall. it doesnt even fall that far and it looks fine. i think just about everyone does that. even if you change the boot also, it will still just hang there unless you get a boot that connects to an aftermartket ****.
Old Jan 31, 2003
asianmatrix02's Avatar
asianmatrix02 is an unknown quantity at this point
to fix that hanging boot collar, just go to home depot or anywhere and buy a bushing used for toilets or sinks. get one that will fit snuggly on the shaft of the shifter. put it under the collar(after removing the center console) and use the bushing to hold up the boot collar. this is what i did and everyone compliments me on the shift ****. i have the type r **** so everything matches. it will look as though u got the **** out of the factory.
Old Jan 31, 2003
4bangin's Avatar
ya you can try that too. i did the same thing but with double sided foam tape. it worked well and i did get compliments on it. then when it turned cold, the tape froze and the collar slide back down, so i just took it off. i have the dc gunmetal **** so it matched pretty good as well. i may have to try the rubber thing, never thought of that.
Old Jan 31, 2003
Quote
[hr]Originally posted by: 4bangin
ya you can try that too. i did the same thing but with double sided foam tape. it worked well and i did get compliments on it. then when it turned cold, the tape froze and the collar slide back down, so i just took it off. i have the dc gunmetal **** so it matched pretty good as well. i may have to try the rubber thing, never thought of that.[hr]
the rubber bushing works perfect and don't have to worry about it slipping in any weather condition. looks as though it was made for the car.
Old Jan 31, 2003
slicksivik's Avatar
anyone got a diy center console removal on the 03? i am having problems too, kinda cant get it off with the armrest storage there. do i need to take that off or something?
suburbanite
Jul 17, 2015 03:05 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
muttleytm
Jul 11, 2015 06:00 PM
General 7th Gen
Jul 9, 2015 10:17 PM
ballmich
Jul 9, 2015 11:59 AM
