Camber kit with Teins?
Old Jan 27, 2003
bobbyd's Avatar
bobbyd is an unknown quantity at this point
If I get the Tein SS will I need a camber kit? Thanks
Old Jan 27, 2003
Weaponx12o's Avatar
im not sure.. but i think so. i'd search the members ride section and find people with teins.. if they have camber kits, then the answer is yes.. hehe
Old Jan 27, 2003
Subrage's Avatar
Subrage is an unknown quantity at this point
i think the tiens have built in camber kits
Old Jan 28, 2003
DizWikedCivic's Avatar
Quote
[hr]Originally posted by: Subrage
i think the tiens have built in camber kits[hr]
tiens have buitl in camber kits, im guessing u will need camber kit depend how low u will drop it
Old Jan 28, 2003
bobbyd's Avatar
I thought only the flex had the built in kit??? Dang suspension is confusing me...Thanks guys for the help though.
Old Jan 28, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
I just installed the TEIN SS on my car, it does NOT have built in camber, maybe the flex does, who knows. Anyways, upon installing them I can barely notice the camber is off a little, I'll probably get a camber kit in the spring depending on how my tire wear is. Later....
Old Jan 28, 2003
VNlilMAN's Avatar
The Standard One
Tein ss does NOT have a built in camber kit.
the flex does..
it doesnt matter if you have tein ss or b&gs... whether you need or dont need a camber kit depends on the amount you drop your car... i think i explained this in the suspension faq and i'm sure it can be found in the threads..
but ya whether you need or dont need one depends on the drop.
Old Jan 28, 2003
slikor's Avatar
slikor is an unknown quantity at this point
yep, what VNlilMAN said.
i have Tein SS coilovers and I dropped the front all the way and rear about equal with the front, and i most certainly needed the camber kits i bought, and i also badly needed an alignment after the install, just to you know.
Old Jan 28, 2003
bobbyd's Avatar
This bings me to another question...How low can you go with teins?
And thanks guys
Old Jan 28, 2003
VNlilMAN's Avatar
The Standard One
not low enough[for me]... its only like 2" max... but ya i'll let the tein owners answer
Old Jan 28, 2003
bobbyd's Avatar
Quote
[hr]Originally posted by: VNlilMAN
not low enough[for me]... its only like 2" max... but ya i'll let the tein owners answer[hr]
Sweet, that will be perfect for me cause I was just goig to get the Eibach Sportlines anyway.
Old Jan 28, 2003
IDQcivic's Avatar
Quote
the tein's can go low as hell! I just installed them and with theire recommend settings it gave me like a 2 inch drop, and I can still lower it another inch or so, which would be way too low. I don't know how all you guys can lower your car so much and not worry about scraping. My car scrapes pretty good on small inclines/speed bumps and its not even dropped all the way! I don't understand your logic I guess... Unless you're going for a strictly show car and you're not gunna be a daily driver, but for practical every day driving the Tein's are perfect.
Old Jan 28, 2003
ASWZero's Avatar
ASWZero is an unknown quantity at this point
The Flex's go about 3 inches max all around just like the SS. The Flex has a shorter stroke though and I do not bottom out. I full suspension travel in the front too. Both my front and rear tires are tucked away under the wheel well. Since I got the floor bar, now my front tires rub on the upper fenderwall on hard turns. Without the floor bar, my car did not dive at all, now it does. It handles better now and the tires do not squeal anymore. Just need to get the courage to take the off ramp above 60 mph. Its been raining every now and then and the roads are wet. I do not really want my car in a ditch right now.
I need to higher my car a little bit until I get my sway bars. I scrape almost everywhere(if choose to) and some I cannot even avoid.
Old Jan 28, 2003
VNlilMAN's Avatar
The Standard One
are you serious? i've always thought the teins only dropped like 2" max.. i've seen two pictures where the car is supposidely dropped all the way and it still has a big gap... maybe one day someone could slam the car all the way down and show me pictures? only reason why i never liked teins was cause it didnt drop low enough but if it is 3" that would be nice
Old Jan 29, 2003
IDQcivic's Avatar
Quote
are you serious? i've always thought the teins only dropped like 2" max.. i've seen two pictures where the car is supposidely dropped all the way and it still has a big gap... maybe one day someone could slam the car all the way down and show me pictures? only reason why i never liked teins was cause it didnt drop low enough but if it is 3" that would be nice[hr]
I didn't take any measurements, but I previously had the Eibach prokit which was about 1" drop and with the Tein SS at the recommended setting its about 1" lower now than with the Eibachs. I have 1 finger gap in front and 0 finger gap in the rear. When summer comes, and I put my rims back on.. I will slam it all the way and take pictures for you all to check out...
Old Jan 29, 2003
Firewall's Avatar
Firewall is an unknown quantity at this point
Quote
[hr]Originally posted by: ASWZero
I need to higher my car a little bit until I get my sway bars. I scrape almost everywhere(if choose to) and some I cannot even avoid.[hr]
You wouldn't happen to have picture of your car with that drop, would you?
Old Jan 29, 2003
HCCriminal's Avatar
an0therpin0y
bullshit . no ..the tein ss do not drop 3" .. .. i would've slammed my ride, if it did drop that much !! ...
Old Jan 29, 2003
VNlilMAN's Avatar
The Standard One
[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
see..
but then their website did say 3" i think
Old Jan 29, 2003
IDQcivic's Avatar
Quote
[hr]Originally posted by: dimsum
bullshit . no ..the tein ss do not drop 3" .. .. i would've slammed my ride, if it did drop that much !! ...[hr]
I just put them on, maybe you installed them wrong... read what I just wrote. I had eibach pro-kit with 1" drop, now I have about a 2" drop at recommended setting by Tein because it sits 1" lower than with the prokit, and I could still lower another 20mm which is close to 25.4mm=1" so thats about 3" total, do the math... I wouldn't lie about this!
Old Jan 29, 2003
bobbyd's Avatar
Quote
see..
but then their website did say 3" i think[hr]
Here is what their site says for our cars. I would imagine that it means the fronts can be lowered from 1.1 - 2.7 inches and the rear 1.2 - 3.8 inches???
-1.1 ~ -2.7 Front
-1.2 ~ -3.8 Rear
Old Jan 30, 2003
HCCriminal's Avatar
an0therpin0y
Quote
[hr]Originally posted by: IDQcivic
Quote
I just put them on, maybe you installed them wrong... read what I just wrote. I had eibach pro-kit with 1" drop, now I have about a 2" drop at recommended setting by Tein because it sits 1" lower than with the prokit, and I could still lower another 20mm which is close to 25.4mm=1" so thats about 3" total, do the math... I wouldn't lie about this![hr]
i got my teins installed by a professional tein installer ! he is JDM .. from head to toe ! don't sweat what i said in the previous post .. its just my figure of speech .. !! try to drop u'r ride ..all the way .. take pics .. and show me .. then i'll believe u .. !!
Old Jan 30, 2003
VNlilMAN's Avatar
The Standard One
maybe you guys got different springs? aswzero was saying how teins offer springs that are 1" lower...
Old Jan 31, 2003
HCCriminal's Avatar
an0therpin0y
Quote
maybe you guys got different springs? aswzero was saying how teins offer springs that are 1" lower...[hr]
you could be right !
Old Feb 11, 2003
Intruder's Avatar
Intruder is an unknown quantity at this point
BTW, tein SS's have an available upper pillow ball mount that IS adjustable for camber in the front. I was unaware this wasn't standard, but my father's tein's came with the upper mount (for his RSX-S)....
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
