Sucessful headlight clearing, but.......
Old Jan 7, 2003
clownprince's Avatar
Ricerus Maximus
so this weekend I cleared my headlights, after over a year of wanting to do it and either not having the time or the ***** on that particular day. So I got the headlights out, put them in the oven, baked them, and pried them apart to clear them. Put them back together fine, got them in, put the bumper reattached and bam, a job well done. So I thought. So I'm driving down the road and my left headlight starts winking in and out, so I have a loose ground somewhere probably. Or maybe the hot wire is loose. It doesn't do it all the time, just enough to **** me off. Since I don't like it, and since it might start a small electrical fire, it needs to be fixed. So has anyone else had this problem or am I just a moron? Second question, does anyone have a diagram of which wire is which on the H4 plug? Any help would be appreciated since my voltohm meter is 300 miles away.
Thanks
Clown
Old Jan 7, 2003
IllusiveImports's Avatar
IllusiveImports is an unknown quantity at this point
it might just be the light buld it self. like a house light bulb, when the filimint breaks it will still work if touching the other end, but will flicker ifits bumped. try throwing the other bulb in fron the other side and giggling the wires and see if it still does it.
Old Jan 7, 2003
SOHC's Avatar
I spent 1425 points to do this.
SOHC is an unknown quantity at this point
im gonna clear my lights real soon.. i bought some 4 filement amber leds that look completely clear when off :-D..any advice? i never heard of bakin em! where can i get a nice DIY? i have one but it involves buying kitchen silicone..i heard u can reheat the old stuff instead. thanks!! im sure ur prob can easily be fixed with some patience, good luck
Old Jan 7, 2003
do you have a coupe or a sedan. a coupes are easy you don't even need the oven, but the sedans are a b!tch i kinda took some chrome off when i cleaned the glue off the one i meesed up a little. but its all good cause i am painting them right now and they look hella tight i will post a pic when i am done. if you have a sedan i can give you some good tips so you dont get the glue on the chrome part
Old Jan 8, 2003
ImPoRtRaCeR1's Avatar
ImPoRtRaCeR1 is an unknown quantity at this point
I just cleared my headlights yesterday it took me about 30 minutes to take apart both headlights. I was being very careful though because i didnt want to break anything. In the end I used dap silicone to seal them I think it turned out good I will have to wait till its a little warmer to know if the seal worked good. But in the end the total project was a .
Old Jan 8, 2003
coolness5545's Avatar
coolness5545 is an unknown quantity at this point
there is a diy in the diy section on how to clear your headlights. its not too difficult having no clue what i was doing it took me about 1hour and a half. only problem was i didnt seal ne all the way so it started to condinsate. i just got done resealing and hoping that it is fixed. another hint is that you dont have to take the bumper off all the way. just take off the top part and let the bottom screws or clips hold it there. you can move it around ebough to get to the bolts under the lights.
chris
Old Jan 9, 2003
adadani2001's Avatar
adadani2001 is an unknown quantity at this point
hey i've been wanting to clear my headlights ever since i became a member of this forum, which hasn't been that long. i just cant find the time to do it. since i got a coupe and since you guys here say that it's easier to take a part the healight, will i be needing the kitchen silicone to stick it back together? and will i have to jack up the car as the DIY says? or can i remove the bumper without jacking up the car?
Old Jan 9, 2003
Ricerus Maximus
adadani2001 the silicon is a good idea just as a failsafe against leaking. I reheated the glue and put mine back together but I ran a thin bead of silicon just to make sure they were sealed. You don't have to jack up the car either. Just remove the clips that are around the top of the grill and the screws in the top of the bumper in the fenderwell. then pull the bumper off gently and voila, access to the headlights. Just don't pull on the grill to hard or you might seperate it from the bumper a little, not a big deal to snap back but a hassle all the same.
Old Jan 10, 2003
thanks for the info
Old Jan 11, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
sounds like an electrical problem, not sure where at, but something might be touching a ground wire.
INJEN
Bikergofast
Detailing
Nov 20, 2015 02:34 PM
brash99
Sep 29, 2015 08:42 AM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
