Sponsored by:
Sponsored by: CARiD
Coilover rusted shut!!!!!
Old Dec 16, 2002
SLAMMED01CIV's Avatar
SLAMMED01CIV is an unknown quantity at this point
I have Ground Control Coilovers. I like them but when I went to raise my car for the winter the driver side rear was rusted shut. The allen wrench part with not move at all. I've tried WD-40 and everything. No luck. Do you think they will replace it????[IMG]i/expressions/face-icon-small-mad.gif[/IMG][IMG]i/expressions/face-icon-small-mad.gif[/IMG][IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Dec 16, 2002
XxJDMCivicxX's Avatar
Don't coilover erode if they are used during winter, if theyre not covered this would probably be the reason.
Old Dec 16, 2002
amhtown01's Avatar
try having a buddy help you out. have one person hold those "plier things" that unscrew the coil overs...and one person get 2 tubes that are1 - 2 feet long and stick one in each plier...and force it open. sorta like a torque wrench.
Old Dec 16, 2002
Grey's Avatar
DIY King
You should have grease up the threads before putting it on the car. That's pretty much the only way to prevent that from happening. Unless GC coilovers have chromed threads? I don't even know...
Old Dec 16, 2002
I heard they had some sort of warranty?? Like they would out live the car or something. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Dec 16, 2002
No, the perch isn't stuck. It's the allen wrech part that loosens it up before you raise or lower it. I put the allen wrench in and it won't turn either way.
Old Dec 16, 2002
Bartkat's Avatar
Maybe get someone to drill out the set screw, and then put in a new one.
Old Dec 16, 2002
BigHippo22's Avatar
BigHippo22 is an unknown quantity at this point
Quote
[hr]Originally posted by: amhtown01
try having a buddy help you out. have one person hold those "plier things" that unscrew the coil overs...and one person get 2 tubes that are1 - 2 feet long and stick one in each plier...and force it open. sorta like a torque wrench.[hr]
WTF?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Anyhow, you could probably get it out using PB blaster which is way better than WD 40 and also get your hands on a torch, heat up the perch a little bit, but not the screw, and it should come right out, you could probably get by with just a small butane torch if you don't have a big one.
Old Dec 16, 2002
alloriginal's Avatar
putang inamo!!!
alloriginal is an unknown quantity at this point
Quote
[hr]Originally posted by: Grey
You should have grease up the threads before putting it on the car. That's pretty much the only way to prevent that from happening. Unless GC coilovers have chromed threads? I don't even know...[hr]
Nah, GC doesnt have chromed threads. Because my front right top coilover threads ripped off... now my front left threads are doing the samething. g.d dammit haha
hey slammed01civ... just check and clean your GC's every month because they tend to drop and get dirty.. go to there site and check it out.. i remember reading something about there warranty. hope this helped...
Old Dec 16, 2002
Quote
[hr]Originally posted by: BigHippo22
Quote
Anyhow, you could probably get it out using PB blaster which is way better than WD 40 and also get your hands on a torch, heat up the perch a little bit, but not the screw, and it should come right out, you could probably get by with just a small butane torch if you don't have a big one.[hr]
PB blaster??? What's that? Won't the torch warp the perch?
Old Dec 16, 2002
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
Quote
[hr]Originally posted by: SLAMMED01CIV
I have Ground Control Coilovers. I like them but when I went to raise my car for the winter the driver side rear was rusted shut. The allen wrench part with not move at all. I've tried WD-40 and everything. No luck. Do you think they will replace it????[IMG]i/expressions/face-icon-small-mad.gif[/IMG][IMG]i/expressions/face-icon-small-mad.gif[/IMG][IMG]i/expressions/face-icon-small-mad.gif[/IMG][hr]
Best bet is get some Liquid Wrench from any auto parts store or hardware store. this solvent will break it up for you.
Old Dec 16, 2002
That sounds like the best solution. Thanks man.
Old Dec 16, 2002
dru106's Avatar
ThE CoRRupToR
I was afraid that that was going to happen with coilovers thats why i didnt get them.
Old Dec 16, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
Quote
Quote
PB BLASTER!!! That will do the trick I promise!
Old Dec 16, 2002
RedDragon333's Avatar
Quote
[hr]Originally posted by: dru106
I was afraid that that was going to happen with coilovers thats why i didnt get them.[hr]
same here but ill prolly go all out and get the true Coilovers plus theres no such thing as true winter in TX
Old Dec 17, 2002
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
The exact same thing happened to me. The perch was stuck on the sleeve and wouldn't turn, and my tire was rubbing like crazy. I called up GC and they shipped a new coilover perch/sleeve free of charge (I originally bought my suspension setup directly from them).
Sucks that the coilover locked up, but big props to GC customer service for being really cool about it.
Old Dec 17, 2002
putang inamo!!!
they sent you the sleeves and perches for free? wow.. so if i call them up will they send me new sleeves and perch since my threads are ripping off..
Old Dec 17, 2002
They sent me one coilover sleeve/perch free of charge. This is after they shipped me a special wrench when I complained that I couldn't turn the original perch. I'm not sure if they will ship you an entire set of four, but it wouldn't hurt to try.
GolNat
Nov 27, 2018 03:32 PM
solarpunk70
Apr 12, 2016 11:43 AM
Solo Flow
Oct 4, 2015 07:52 AM
Tedverseti
Sep 29, 2015 05:41 PM
Bikergofast
Sep 12, 2015 01:36 PM
