Help on painting housing on headlights
Old Dec 3, 2002
synikal's Avatar
synikal is an unknown quantity at this point
I plan on clearing, and painting the headlight housing this afternoon. I already have some black primer, black 500 degree engine enamel, and some high temp clear coat. I was wondering if I should use all three?? or do I not need to prime the chrome. Also will the engine enamel stick to the plastic chrome? Also to people who have done this....how much time did it take you to CLEAR and PAINT your headlights. thanks for the help
Old Dec 3, 2002
trevor's Avatar
trevor is an unknown quantity at this point
I just used the 500 degree paint....then clear coat......
It worked fine.....I didn't primer...someone might have dif opinion though........
And time-----I had cleared mine before, that took me (1st time) about 6 hours......cause I was a stupid ****.....the second time.....when I painted the inserts....With paint time to dry and everything, it only took me about 4 hours......
If it's your 1st time, plan on a good day you are doing nothing.......
good luck, trevor
[IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Dec 3, 2002
fraga's Avatar
Wicked Moderatuh
Yeah, I too plan on painting and clearing my lights, so I've read many a post abou this. Some have just painted with no primer, some have even wet sanded before painting. It's all in who you ask. Do a Search and you'll find many threads about this. I know I have. Good Luck.
Old Dec 4, 2002
Boost's Avatar
Boost is an unknown quantity at this point
ive painted mine, and i wish i had primed them, they do flake off if your not careful, the extra 30 mins it takes to prime them is worth it to avoid haveing any of the paint flake off when your forceing them back into the clear plastic shell. if your going to do a mod to your car do it well, half-a$$ing it is the first step down the road to rice-ness
Old Dec 4, 2002
fraga's Avatar
Wicked Moderatuh
Thanks man. That's good to know.
Old Dec 4, 2002
dragoon's Avatar
don't use primer. not if you're using high heat paint, which is ceramic based and will not flake or crack.
Sep 27, 2015 11:33 AM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
Mannimarco
Sep 7, 2015 10:01 PM
MamaBear2015
Sep 4, 2015 09:04 PM
