Problem with new CAI i just bought and installed...help quick please!
Old Oct 11, 2002
slammed2k2's Avatar
slammed2k2 is an unknown quantity at this point
i just bought a R1 cold air intake, and my engine light is on and also i dont know where to plug the electric thing!?
and can someone explain what this hole is for? heres a pic
Old Oct 11, 2002
macrossranma's Avatar
macrossranma is an unknown quantity at this point
whats the problem?
Old Oct 11, 2002
StLVtec's Avatar
StLVtec is an unknown quantity at this point
The one on the far right is where u plug int eh o2 sensor
Old Oct 11, 2002
slammed2k2's Avatar
how do i plug that in?
Old Oct 11, 2002
StLVtec's Avatar
There should be an o2 sensow over there to the left and it should just push right on in it. Thats how it was more my injen , and then switched to aem and there both the same ways. hope this helps
Old Oct 11, 2002
slammed2k2's Avatar
i need more detail
what do i plug in?
and where do i plug the plastic clipping one?
Old Oct 11, 2002
StLVtec's Avatar
Okay the one that is sticking out and has a hole in it. There should of been a hose that cam with the kit.
the hose goes on the intake and goes onto the piece that is sticking out on the engine it is directly across from it when the intake is on. Straight across. As for the whole on the side with the rubber seal around it , thats where the electic sensor plugs into it should just go right in there. Good luck with it , not to hard. And dont forgot to unplug ur negative battrey during install, so it resets ur ecu.
Old Oct 11, 2002
slammed2k2's Avatar
ok so i got he 02 sensor in it, now my engine light is still on?
WHY?
do u have to tape it on, and its abit tight too ?!? the wire is tighttt i mean
o and whats all this about the transmission bracket? i didnt do ne thing for it or with it
Old Oct 11, 2002
Importracer's Avatar
Importracer will become famous soon enoughImportracer will become famous soon enough
uhh the o2 sensor is supposed to be snug, the tranny bracket needs to go on to support your intake, the engine light will go off only if you reset your ecu!.
Old Oct 11, 2002
dacivic's Avatar
dacivic is an unknown quantity at this point
reset ecu mean unconnect the negative of your car battery(the one with black cover) for about 10mins. Then connect it back.
Check this DIY install for AEM CAI, should be same DIY Install
Old Oct 11, 2002
civicvtec1ps's Avatar
Search and Learn
reset ecu also
Old Oct 11, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
THat is not the o2 sensor!!! the o2 sensors are on the exhaust and control emissions, the sensor you guys are refeering to is IAT, intake air temperature sensor... either way it needs to be plugged into the intake for the ecu to function properly!
Old Oct 11, 2002
IDQcivic's Avatar
Ant the other hole should have a rubber tube running to the back of the engine, this is the PCV hose.... make sure that is working too...
Old Oct 12, 2002
Dzel's Avatar
Dzel is an unknown quantity at this point
rESET UR ECU JUST BY UNPLUGGING UR BATTERY...IF U HAVE A STOCK RADIO REMEMBER UR ANTI THEFT FEATURE AND PUNCH IN THE CODE =)
Old Oct 12, 2002
Panda
Guest
Posts: n/a
just reset the ECU...everything should go back to normal then...
Old Oct 12, 2002
slammed2k2's Avatar
thanks guysss
i figured out where to plug the IAT, and the engine light went away after driving about 30 minutes with it plugged in!
i didnt reset my ecu tho, but i gueess it did it on its own and thats why it went away
Old Oct 14, 2002
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
The "electric thing" is not an 02 sensor it's an IAT which monitors the temperature of your intake adjusting the fuel as needed (you will notice that you will lose significant gas milege) this should be snug in the rubber grommet. The other hole (which comes out off the intake) is a breather line which attaches behind your valve cover. You NEED to reset your ECU!!! to do this I recommend (if you have a radio with presets) opening your fuse box and pull the fuse labeled "F.I ECU" (Fuel Injection ECU) pull this for about 10-15 minutes. After putting it back in start your car and DONT TOUCH THE GAS for 10 minutes, turn off, on, off, on and your good to go..so stomp on it and hear it whistle, and groan at high RPM's...FYI: You should reset your ECU after any modification. [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
mistermenphis22
Apr 3, 2016 08:06 AM
manicEL
Dec 10, 2001 06:33 PM
Daniel420
Nov 9, 2001 08:36 PM
MooCoW
Nov 9, 2001 05:22 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
