Suspension FAQ
Old Oct 9, 2002
VNlilMAN's Avatar
The Standard One
Suspension FAQ
What lowers your car __ inches?(*note these are according to the companys' website)
Springs.........................……….Drop.......... ...............Part Number
Apex..................................…~1.6-1.8...…………….......180-4000
Arospeed..............................???????????? ????????????
Eibach Prokit.....................….1.00 (F)/1.00 (R)..........4051.140
Eibach Sportline....................1.40 (F)/1.40 (R)..........4.5140
Goldline 2 Door.....................1.75 (F)/1.75 (R)..........GPS-0106
Goldline 4 Door.....................1.75 (F)/1.75 (R)..........GPS-0107
H&R Sport.........................….1.30 (F)/1.30 (R)..........51866 *not for 4 door EX
Intrax Sport..........................2.00 (F)/1.80 (R)..........35.1.030
Intrax Super Sport.............…..2.50 (F)/2.30 (R)..........35.2.030
Matrix................................…2.75 (F)/2.50 (R)..........MS-101
Neuspeed 4 Door Sport..........1.75 (F)/1.50 (R)..........55.20.61
Neuspeed 2 Door Sport..........1.75 (F)/1.50 (R)..........55.20.62
Neuspeed 2/4 Door Race........2.25 (F)/2.00 (R)..........55.20.68
Progress………………...............…1.80 (F)/2.00 (R)..........40.1006
Skunk2..............................…2.50 (F)/2.25 (R)..........519-05-1570
Suspension Technique............????????????????????????
Tanabe Super Down Precedo...1.60 (F)/1.80 (R)...........TPR044
Tein.....................................1.3/1.4…………….SKA22-AUB00
Do i need a camber kit?
You dont NEED a camber kit even with a 5" drop. however, with any type of drop(even if its .5") you should get one in order to get a correct alignment. most people will say that with a drop lower then 2", a camber kit is HIGHLY recommended. just think of it this way would you like to save $200 by not getting a camber kit but replace your $400-500 tires twice a year? just invest in a camber kit, it'll save you in the long run.
Whats the difference between springs, adjustable springs aka sleeved coilovers, and true coilovers?
springs - fairly comfortable ride, set height ~$100-$200
sleeved coilovers - ride is usually rough/bouncy, adjustable height ~$300
true coilovers - coilover and shock in one designed to work together giving a great ride. adjustable height ~$800-$1300
Will lowering my car void my warranty?
Yes and No. by law they have to prove that lowering your car cause the problem. whether you have a easy/hard time getting something repaired under warranty is up to the dealer. most likely your suspensions warranty will be voided but all other warranties wont. however there are exceptions. some dealers will allow you to lower your car with only the struts not being covered under warranty. some dealers will even agree to give you all warranties only if they install it for you. n there are some that will say you need to pay for your badd tranny because your warranty is voided due to lowering your car. that is when you should take action. call Honda of america or get lawyers, do whatever it takes to get it fixed under warranty because chances are lowering your car didn't cause the tranny to break. if your worried about warranty issues, best bet is to call up your dealer and ask what is allowed and what is not.
How long will my stock shocks last?
it mainly depends on the springs. also the way you drive and luck. i've heard some people blowing their shocks in one week with the prokit(about 1") and others going for 2 years with the neuspeed sports(1.7"). but most likely you wont need it for awhile with anything higher then 2". so ya for a drop lower then 2" its best to get one so that you wont have to pay for installation again or for you DIY you dont have to waste that much time again. n if your drving 100mph over speed bumps then chances are your shocks are gunna blow faster. but if your going over them at 1 mph then you have a better chance of them not blowing.
Do i have to get new struts as well?
besides worrying about your shocks blowing, do you care about the ride quality? the ride on lowering springs is never going to be the same as stock. their going to be stiffer and your going to feel more bumps. it will probably be more bouncy as well. usually the lower the drop, the worse the quality. and sport springs are going to be worse then race. aftermarket shocks or even shorter shocks are going to improve the ride quality. right now the only ones available for our cars are konis(these are inserts so you'll have to modify your stock struts in order to put these on your car because these are not full struts).
Old Apr 28, 2003
chibOi's Avatar
chibOi is an unknown quantity at this point
very helpful
Old Jun 12, 2003
Slow+Furious's Avatar
Slow+Furious is an unknown quantity at this point
YYOOOOOOOO!!!!!
Just wha newbie needs thanx VNlilMAN!!
Old Jun 26, 2003
Derek-CEO's Avatar
Derek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz Erthang
added to FAQ section
Old Jul 1, 2004
glovas's Avatar
glovas is an unknown quantity at this point
Unhappy
I was trying to put coilovers on, found out they where the wrong ones for my car. when i put the strut back together i noticed a binding noise when i trun the sterring wheel , what could it be? i know it needs a alinement .
Old Oct 17, 2006
yamahaSHO's Avatar
yamahaSHO is an unknown quantity at this point
---- If you're into spirited (canyons, track, autoX, etc.) driving and your springs over-power you struts, prepare for a rue awakening when you the car gets up set in a turn. If it is for street driving, it may not as big of a deal.
Old Oct 18, 2006
Biggie Deaf's Avatar
Biggie Deaf is an unknown quantity at this point
So....I do have to buy new struts, anyway? So, in my case, I have to buy my suspension AND struts?
Old Oct 18, 2006
yamahaSHO's Avatar
Struts are considered suspension. If you get springs, it is HIGHLY recommended you get new struts.
Old Oct 19, 2006
robbclark1's Avatar
Retired suspension supermod.
There is a big thread up top with the FAQ in it. If you do'nt know about your suspension, I suggest looking on how stuff works for mcpherson struts.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
