RSXS Sway Bar and some weird noises!!! Help!!!
Old Jul 14, 2002
blouisgod's Avatar
Life Begins > 6800rpms
just installed the rsxs sway bar on my ex coupe with a magnaflow cat back. its works well but turning right and swinging the rear out creates a creaking noise. i dont think its the exhaust cause there are no signs of hitting so im thinking i should just reinstall the bar as evenly as i can? does this sound right?
Old Jul 14, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
did it come with urethane or rubber bushings?
if it came with urethane...did you grease them? if not they squeek.
Old Jul 14, 2002
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
i put an EX front lower sway bar onto my LX and have noticed a creaking noise myself, i think its just due to a tighter fit on the chassis. i think the energy suspension bushing kit will releave some tension on the suspension and eliminate that creakin noise....but....
(1) im not sure if this product is available yet...
(2) im not sure if this product replaces that specific urethane bushing for the sway bar.....
Old Jul 14, 2002
blouisgod's Avatar
I am thinking of getting the urethane bushings for it, right now i am using the honda rubber ones. i moved the bar over to the right more in hope of clearing my exhaust if that is what is creating this noise... so far, so good. but i have to say i think that it is do to the suspension being more reinforced and being able to travel less. thanks for the help and ill keep you guys updated, especially those with a 2.25 catback and thinking about this mod.
Old Jul 15, 2002
Simkin's Avatar
Simkin is an unknown quantity at this point
The noises you are hearing could be unnatural chassis flex. If you don't already have a rear lower tie-bar, this maybe a good time to get one.
]SiMKiN[
Old Jul 15, 2002
DogstyleEX's Avatar
DogstyleEX is an unknown quantity at this point
try something for me.. cause i'm getting the same thing... grab ahold of an end link and shake it hard.. is that the noise you hear?
Old Jul 15, 2002
CapYoda's Avatar
Escaped Convict
Quote
[hr]Originally posted by: DogstyleEX
try something for me.. cause i'm getting the same thing... grab ahold of an end link and shake it hard.. is that the noise you hear?[hr]
thats probably whats going on...
your sway bar attaching to the endlink may be too loose, OR, too tight... torque it to 28 lb.ft will be good I think. and the mounting is about 16 lb.ft
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
BootyDo
Jul 26, 2015 10:38 AM
fordover
Jul 11, 2015 09:10 PM
1khilari
Jul 9, 2015 08:12 PM
