wtf is a camber
Old Jul 8, 2002
MistaFreeze's Avatar
MistaFreeze is an unknown quantity at this point
wtf is a camber
u told me i need to get a camber for my car if i drop it, what is a camber and how much will it cost?
Old Jul 8, 2002
VNlilMAN's Avatar
The Standard One
when you have a slammed car and look at your car from the back, the top of your wheels tilt in and look like this / \. thats negative camber... if you raise your car, your camber looks like this \ /. which is positve camber. any time you lower/raise your car, the camber is going to change and this is going to cause uneven tire wear since one side of the tire has more traction on the ground then the other.. obviously the lower you drop your car, the worse the cambers going to be and so the more crucial a camber kit is going to be...
but ya your probably talking about the camber kit, this allows the camber to be adjusted into spec(cause the stock ones aren't adjustable, well they are but very² minimal). whenever you lower/raise your car its recommended you get one but ya the lower/higher you drop/raise it the more its needed... i have neuspeed sports and probably wont get one cause i dont think it would effect the tire too much. if i'm wrong i guess i'll find out the hard way tho...
the fronts are going to cost about 30 and the backs about 150. however i have heard of people getting both for 155 shipped, not sure where tho.
Old Jul 8, 2002
2cute's Avatar
2cute is an unknown quantity at this point
I have explained it numerous times in detail. I am sure if you did a search you could find it.
Old Jul 8, 2002
sspem2's Avatar
em2
buy a camber kit cuz if u dont now ur going have 2 spend alotta $$$ on tires and on ur suspension in the future. a camber kit costs like 100.00 just 4 the front then u gotta buy the back. its cheaper in the long run. go thru the parts section u will find camber kits 4 sale 4 cheap or call rob at tornactive and say ur a member on this site and he will hook u up.
Old Jul 8, 2002
2cute's Avatar
You do not need a camber kit for the front of the 7th gen vic. Or for that matter any McPhearson strut set up. It is a waste of money.
Old Jul 8, 2002
VNlilMAN's Avatar
The Standard One
Quote
[hr]Originally posted by: 1siksivik
buy a camber kit cuz if u dont now ur going have 2 spend alotta $$$ on tires and on ur suspension in the future. a camber kit costs like 100.00 just 4 the front then u gotta buy the back. its cheaper in the long run. go thru the parts section u will find camber kits 4 sale 4 cheap or call rob at tornactive and say ur a member on this site and he will hook u up.[hr]
the back costs more like 100, not the front. the front, you only replace one(or two) bolt. the rear you replace the control arm. the front you wouldnt even need cause the camber is barely effected with macpherson struts... search and you should find 2cute's explanation for this
Old Jul 8, 2002
icey's Avatar
icey is an unknown quantity at this point
please search next time
-tia
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
meicalnissyen
Sep 25, 2015 12:12 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
hatch90
Sep 3, 2015 08:45 AM
