How difficult to install headers?
Old Jun 23, 2002
Decamo's Avatar
Decamo has a little shameless behaviour in the past
How difficult is it to install headers? Can I do it in my driveway with jackstands and hand tools? If I put on an HP racing header w/hi flow cat can I easily switch back for emissions?
Old Jun 23, 2002
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
unless you are pretty good with cars i would recomend taking it to a pro just to make sure its right
Old Jun 23, 2002
WhiteRiceBoi's Avatar
WhiteRiceBoi is an unknown quantity at this point
dude its a piece of cake!
most of the work involved with cars is simply just common sense, why do you think Gus and Bubba can work on your car and not mess it up too bad, the only thing I have hard time trusting myself to do is stuff I really dont know, like the brake system, and alot of the electrical stuff.
Old Jun 23, 2002
AFlyer's Avatar
AFlyer is an unknown quantity at this point
it's a piece of cake dude, if you have jackstands and a torque wrench you'll be good to go. prepare to be frustrated by the lower bolt that holds the heat shield on to the stock header though. everyone i've talked to has had trouble with breaking the torque on that thing cause of rust.
Old Jun 23, 2002
Decamo's Avatar
I do have one power tool, an impact wrench. I guess that will help. I've done my springs so i guess i can handle this. Just wanted to know if there was things to look out for like if I get HP racing headers will it line up properly?
Old Jun 23, 2002
LeroyBrown's Avatar
LeroyBrown is an unknown quantity at this point
i can do the intake and exhaust- but i'm letting the shop do my headers...
Old Jun 23, 2002
sadboy916's Avatar
i have a lx and i whent to the body shop for headers cus it needed to be welded and cut
Old Jun 23, 2002
Mbow's Avatar
I just put a dc header on mine a week ago. I simply sprayed all the bolts with some wd-40 about 8pm and went to install the header around 11pm. Every bolt broke free easily. Just take a few minutes and spray all the bolts a little while before you do the install. I simply jack up one side of the car just enough to be able to slide under and get to the bolts attaching the header to the downpipe. I have no idea why anyone would pay to have this installed. It takes 45mins MAX to install a header. Some people just aren't inclined in this way but most are.
Old Jul 2, 2002
Ichiban's Avatar
Ichiban is an unknown quantity at this point
How do you get to the right most bolt thats holding in the header. The wires around the altanator (spell check) is blocking the way.
Old Jul 2, 2002
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
Quote
[hr]Originally posted by: Decamo
How difficult is it to install headers? Can I do it in my driveway with jackstands and hand tools? If I put on an HP racing header w/hi flow cat can I easily switch back for emissions?[hr]
its real simple, just make sure you have a good set of sockets.
Old Jul 2, 2002
bhaz413's Avatar
Quote
[hr]Originally posted by: AFlyer
it's a piece of cake dude, if you have jackstands and a torque wrench you'll be good to go. prepare to be frustrated by the lower bolt that holds the heat shield on to the stock header though. everyone i've talked to has had trouble with breaking the torque on that thing cause of rust.[hr]
I used a breaker bar and it came off with a quick push.
Old Jul 2, 2002
bhaz413's Avatar
Quote
[hr]Originally posted by: AznThug08
How do you get to the right most bolt thats holding in the header. The wires around the altanator (spell check) is blocking the way.[hr]
just use a extension with a breaker bar. took me 2 seconds.
mjdiaz89
Jun 21, 2016 09:26 PM
Misfit2613
Jul 30, 2015 09:49 AM
S1N7H3T1C
Jul 21, 2015 05:20 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
fvckbg
Jul 7, 2015 07:08 PM
