Where to drill a hole in the firewall
Old Jun 21, 2002
SilverBUll8's Avatar
SilverBUll8 is an unknown quantity at this point
Where to drill a hole for firewall
I have read some of the firewall threads but I still can find any. I know some people has said they made there own. Where is a good spot to drill. I have a 2 door coupe ex. Any info would help thanks.
SP
Old Jun 21, 2002
2cute's Avatar
2cute is an unknown quantity at this point
What are you trying to do? The car already has a firewall. So what are you trying to add or mod?
Old Jun 21, 2002
Yeah i have a neon under and i run the wires in the car from the out side through he door. I need to have a hole so i can get more wires in. And i ment in the firewall
Old Jun 21, 2002
StraightEdgeCivic's Avatar
StraightEdgeCivic is an unknown quantity at this point
theres an existing hole that some people use....check the diy for amp wiringhere
edit: u run wires from under ur car through your door???
Old Jun 21, 2002
2cute's Avatar
Just use one of the existing holes there are plent of them and plenty of space. It isn't worth drilling a new one.
Old Jun 21, 2002
Pedrito's Avatar
Pedrito is an unknown quantity at this point
if u pop ur hood look on the passenger side towards the bottom their is like a rubber thing....tape coat hanger and ur wire together and put it through their u can see it under ur floormats inside the car passenger side see if this helps....
Old Jun 21, 2002
GteKDynamics's Avatar
GteKDynamics is an unknown quantity at this point
i think the firewall in the coupes are plugged up with a white plastic looking thingy.......
I remember i had to pull the plastic out before i could get my 4 gauge wires through
Old Jun 21, 2002
VNlilMAN's Avatar
The Standard One
ya its in the passenger side, get under there where the feet go, its very close to the center console.. if not you could always go through your fender, that how i ran my amp wire.. but ya i'm sure you could find other holes
jdh022764
18
Nov 3, 2015 06:44 AM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
Islesfan
Sep 29, 2015 03:42 AM
jsmithe2010
Sep 25, 2015 07:42 PM
nixyfior
Sep 14, 2015 08:32 PM
