Camber kit?
Old Jun 7, 2002
2001CivicEx2dr's Avatar
2001CivicEx2dr is an unknown quantity at this point
Camber kit?
Is it safe/practical to only have a front camber kit and not a rear? I'm only dropping less than 2 inches with the neuspeed sport springs so paying so much for rear correction doesn't seem worth it.
thanks
andrew
Old Jun 7, 2002
TOOLOWCIVIC's Avatar
I don't think there will be a problem with just having the front camber kit but you might need it for the back also with a 2 inch drop.
Old Jun 7, 2002
FamilyMan's Avatar
FamilyMan is an unknown quantity at this point
You will certainly need a rear camber kit. I think you can get by without one in the front. You have some limited ability to adjust your front camber without a kit, and with a 2" drop you MAY be OK.
Old Jun 10, 2002
civicpimpin01's Avatar
civicpimpin01 is an unknown quantity at this point
Well, since you are dropping less than 2 inches you should be fine. Like I always say though, having a camber kit can't hurt you in the long run. But if you want to start off without one in the rear you will be alright, but you can't go wrong if you do get one. I wouldn't even bother with the front though, JMO.
Old Jun 10, 2002
VNlilMAN's Avatar
The Standard One
ya the front is a waste of money imo, get the rear, it'll probably save you in the long run
Old Jun 12, 2002
HippyCivicEX012's Avatar
HippyCivicEX012 is an unknown quantity at this point
The rear is replacing actual components
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
