Camber kit?
Camber kit?
Is it safe/practical to only have a front camber kit and not a rear? I'm only dropping less than 2 inches with the neuspeed sport springs so paying so much for rear correction doesn't seem worth it.
thanks
andrew
thanks
andrew
You will certainly need a rear camber kit. I think you can get by without one in the front. You have some limited ability to adjust your front camber without a kit, and with a 2" drop you MAY be OK.
Well, since you are dropping less than 2 inches you should be fine. Like I always say though, having a camber kit can't hurt you in the long run. But if you want to start off without one in the rear you will be alright, but you can't go wrong if you do get one. I wouldn't even bother with the front though, JMO.
Dave Brabant
20
Oct 6, 2015 12:44 AM
Hutch1051
Sep 29, 2015 09:20 AM
