AEM CAI HELP....
Old Jun 5, 2002
1jazzyciv's Avatar
1jazzyciv is an unknown quantity at this point
AEM CAI HELP....
Ok - so I am a relative newcomer to doing installs/mods myself and I fought with the CAI last night for about 2 hours. Couple of things came up - 1, it's extremely close to the hood, should I be worried? 2, the mounting points did not line up all together that well - particularly the top point on the upper bar. Did anyone else have a tough time with this? 3, the clearances are very small - should I worry about rubbing in the future, will it move as it "settles in"?
I reset the ECU but it didn't seem to help, it sounds like the car is getting too much air and the cars bogs a bit under hard power.
Just let me know if you have experienced any of these things or if there is someting I can do to "fix" the issues.
Thanks in advance.
Jason
Old Jun 5, 2002
DaPipeLayer's Avatar
AAAAHHHHH!!!!!
DaPipeLayer is an unknown quantity at this point
1.) After driving around for awhile, open your hood and check if it has hit anything, if not, then you are ok.
2.) The only thing I can think of right away is not to tighten all the bolts down one at a time. What I mean is, before you start to tighten everything up, make sure all the bolts are in their places and are at least half way in. Then start tightening them from various places (like you would with lug nuts). You get what I mean?
2.) If you can't move the intake with your hand and its not touching anything at all, then you should be okay. Just every once inawhile check to see if its getting loose, other then that, you should be ok.
It does take some time for the ECU to adjust to the new settings, even after you have reset it. Just cruise around and maybe drive it hard once in awhile. I read somewhere that you need to drive for like 100 miles for the ECU to adjust itself to the new intake, but I'm not quite sure on the number.
Old Jun 5, 2002
ph0ng's Avatar
ph0ng is an unknown quantity at this point
When I put mine in, everything seemed to go in very nicely. The mounting points lined up with out too much effort on my part.
Yes the clearences are pretty small for some parts, especially for the cone filter (almost resting against trany). But that is mostly due to that I mounted the AEM clutchline bracket above the nut on the transmission mounting bolt, instead of below it, and I put the rubber spacer bolt on the top side of the bracket, not the bottom like the instructions said.
but beyond that, did you reference my DIY at all?
AEM DIY
What model car do you have? and what model intake did you get?
Old Jun 5, 2002
djlunatic's Avatar
djlunatic is an unknown quantity at this point
DaPipeLayer is right. the intake is high @ first don't worry about that.
i found with the aem intake to avoid install hassels start from the bottom @ the filter and build it up to the throttle body. the first time i installed an itake i went top to bottom and it was not lined up.bottom to top always works.
as long as the intake is firmly positioned and the hose clamps are tight you'll be fine.
after about 2 tanks of gas the ecu will be working fine. i have aem cai with a bypass valve, after the ecu was reconfiguired i gained gas mileage.
Old Jun 5, 2002
1jazzyciv's Avatar
I actually did print out your DIY - and the AEM instructions are pics as well - some anyway. I have an EX, 5sp and I bought the AEM CAI model #21-500 - I think. I got it from Rob so I know its right - it was just a bit unsettling. I have done Mustangs and Camaros - as well as some older VW's but this was the tightest I have seen. Today it seemed to get better, it still sounds like it's sucking too much air and it gulps/wisps when I shut it down. The power is good and it's definetly bot hitting the hood tat I can see - but it is close.
I stopped by the dealer - one of the guys there has a modded up EX as well and his looked pretty much the same.
Thanks for the help - let me know if you think of anything else.
Jason
Old Jun 5, 2002
Toretto's Avatar
Toretto is an unknown quantity at this point
does the pipe curve to the wheel well or towards the front of the car?
you do got to mess with it a little, i got a little gash on the side where
it rubs against the battery tie down rod. it looks like it will hit but it wont...
my blue car
Old Jun 5, 2002
Lianjie's Avatar
Lianjie is an unknown quantity at this point
i have the same setup as jazzy and i haven't noticed any problems either... seems fine to me[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jun 5, 2002
ph0ng's Avatar
Toretto - the lower pipe stays to the front of the car... just behind the radiator and in front of the trany.
I believe the Injen CAI can go into the empty space just behind the front bumper and wheel well, but requires some cutting away of the splash guard.
Check the DIY page, it's got some detailed pics.
Old Jun 5, 2002
happynappy82's Avatar
happynappy82 is an unknown quantity at this point
My AEM CAI has rubbed slighty since it was installed a bout a year ago. there is a small part on the top of the intake with no paint. THERES ALSO A DENT in my hood from accidently shutting it to hard 1 time. so i got a nice dent in my hood and rub's through the paint both on the intake and on the underside of my hood. its cool though
jason
Old Jun 6, 2002
TEKNIQ's Avatar
TEKNIQ is an unknown quantity at this point
Quote
[hr]Originally posted by: happynappy82
jason[hr]
Same here....
[IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Jun 6, 2002
aferenz's Avatar
aferenz is an unknown quantity at this point
The hissing noise when you shut off is normal, at least I hope it is. It does that for me and I've put put 2,000 miles on my CAI in the 3 months I've had it.
Old Jun 6, 2002
CivicRacer18G's Avatar
CivicRacer18G is an unknown quantity at this point
I've had the hissing noise for almost 5,000miles when I shut off.So i asume it's normal. You shouldn't have any clearance hood problems, i have a lot of distance from hood to intake bend. Only problem i had installing my AEM CAI was taking off the tranny bolt. YOur ca shouldn't seen sluggish after installing it, never experienced that. Just do some highway driving.
Old Jun 6, 2002
Blown's Avatar
Blown is an unknown quantity at this point
Man, I guess no one here really drove a 2 stroke bike before. You can sure hear the intake on them. When you're hard on the throttle, you'll initially hear a bog but it's soon gone. The intake noises are normal! When I shut my car off, it hisses as well. I haven't had any problems with clearances or installing. It was a breeze.
Old Jun 6, 2002
ph0ng's Avatar
the hissing noise is just a normal running condition of your engine. The reason why you never notice it with the stock intake/resinator, is because all intake noise is baffled. So now with just a straight pipe, you are hearing all the little noises and sounds of your engine running normally.
If you got some time, take the upper intake pipe off so you can see the TB, turn on your engine and have someone rev for you... you'll understand why you hear hissing and all the other dynamics of the sounds from the intake.
LilNic13
Nov 28, 2015 10:26 AM
carid
Nov 7, 2015 01:46 AM
naokigoffi
Aug 30, 2015 06:19 PM
spyder13
Jul 31, 2015 06:31 PM
Theshwartz35
Jul 17, 2015 11:13 PM
