vtec works fine when cold but bucks at 3500rpm when up to OT.
Old Apr 29, 2022
benjafish's Avatar
probably fixing my stupid civic.
benjafish is an unknown quantity at this point
I have a 2004 Honda civic EX sedan and it runs just fine up until it gets up to temp. When it is up to temp it bucks at 3.5k.
Just replaced head gasket, cam sensor, timing belt, water pump, rad hoses, coolant sensor and fan switch.
Any ideas?
Old Apr 29, 2022
Re: vtec works fine when cold but bucks at 3500rpm when up to OT.
you are in limp mode
check codes
Old Apr 29, 2022
benjafish's Avatar
I have no codes and no engine light. Also I have put it in limp mode and is is a much softer limit. This is a much harsher buck vs. normal limp mode.
Old Apr 29, 2022
what do you mean by you put it in limp mode?!?
The ECU does it no matter how much you want to make it go away as long as you have the issue that triggered the mode?!?
Old Apr 29, 2022
GolNat's Avatar
Prelude Owner
Check to make sure you didn’t miss a sensor. OEM cam sensor? Did you verify timing?
Old Apr 29, 2022
Colin42's Avatar
Going to guess you used a non-oem cam sensor. Put an OEM sensor in it
Old May 2, 2022
benjafish's Avatar
Timing seems to be correct. Sensor is not OEM. Would that be enough to do that? The old sensor was fine I just did the sensor a a precaution while I had it apart. I could put the old one back in?
Old May 2, 2022
benjafish's Avatar
I purposely pulled the VTec pressure switch and spool valve plugs apart. It set codes and drove it. It was more like a rev limiter where as normally it is much more harsh
Old May 2, 2022
thanks for clarification, in the internet you never know how much someone knows what they are talking, so details are always welcome
Old May 2, 2022
honda engines dislike aftermarket sensors, many solved issues after getting OEM
Old May 2, 2022
Colin42's Avatar
Put the old one back in
Old May 4, 2022
Rubberboots's Avatar
Rubberboots is an unknown quantity at this point
Do all aftermarket valves and other parts cause problems...I replaced a VTEC valve and getting a check engine light now?
Old May 4, 2022
Do they dislike VTEC valves as well please?
Old May 4, 2022
Just the bad ones.
NEW stands for "Never Ever Worked"
Get actual fault codes first.
THEN guess lol
Old May 4, 2022
P1269 Vtec valve
Old May 4, 2022
Colin42's Avatar
Most likely new valve is junk
tailgunn
Engine start problems
Jun 26, 2021 09:39 PM
Michael Johnson
Apr 24, 2016 12:41 AM
PK2K1
Nov 21, 2002 11:32 PM
MSoft
Aug 22, 2002 08:56 AM
GuSTo
Aug 15, 2002 08:37 AM
