Complete rebuild
Old Feb 1, 2022
Berteasterly202's Avatar
Berteasterly202 is an unknown quantity at this point
Complete rebuild
I've got a D17a1 had a rod knocking tried to drive it home and car lost all power it'll still start up but no power to drive. Recommendations on parts that I should change while I've got it out and tore down please this was my plan as of now on parts purchased...
Old Feb 1, 2022
Re: Complete rebuild
rear main seal, check front crankshaft seal also, see if harmonic balancer in one piece
Old Feb 1, 2022
clean EGR if it have it?
Old Feb 1, 2022
So I should be able to use the old connecting rods right
Old Feb 1, 2022
BrotatoChip's Avatar
Super Moderator
I would just put in another used engine.
If you're set on rebuilding the crank and rods need to be checked by a machine shop, there's a good chance they have damage. The block and head should also be cleaned to get out any metal shavings from the bearing.
Old Feb 1, 2022
It cheaper to do the rebuild than any of the replacements I've found
Old Feb 1, 2022
Colin42's Avatar
Engine should be sub $500 all day. Rebuild will be at least double that
Old Feb 1, 2022
Super Moderator
And that's assuming it works unlike some other users we've seen here.
Old Feb 1, 2022
Other than replacing other parts the complete overhaul rebuild kit is only $324 and ill do all the labor my self that's not a problem plus I've already got a new rear main seal, egr, vtec solenoid, ecu with wiring harness, and a vtec cylinder head
Old Feb 1, 2022
have you read about the key programming part?
oh, shoot, just noticed your kit already have the rear seal...
Old Feb 1, 2022
No what about it cause I've got the ignition switch and key that goes with the ecm as well
Old Feb 1, 2022
then you have it.
programming keys is the pain point
ah, clean the PCV valve too
Old Feb 1, 2022
Why clean it might not replace it it's a very low price item they range from a $1.27 to $19.99
Old Feb 1, 2022
Realistically speaking what's the probability mean connecting rods are done for because I'm having major issues finding replacement connecting rods I do not want to go with used one's
Old Feb 1, 2022
FRSam's Avatar
Click Here
Take them to a machine shop. It’s not worth reusing them blindly.
Old Feb 1, 2022
So if their not reusable will they charge me for checking them or nah
Old Feb 1, 2022
FRSam's Avatar
Click Here
Of course. They'll be taking the time to do it. If you go to a shop, they're going to charge you for their time. It should be no more than probably 1 hour of labor though.
Old Feb 2, 2022
Colin42's Avatar
If you don't understand the value of a machine shop, then just slap everything together and move on with your life
Old Feb 2, 2022
Super Moderator
You cannot cut corners when rebuilding an engine, unless you'd like to rebuild it again soon.
Old Feb 2, 2022
I'm not trying to cut corners when I do something I so it right that's why if I can't use the ones I have then im wanting to replace them with new ones was just curious what the going rate on having the rods checked out
Old Feb 2, 2022
Colin42's Avatar
Depends on the shop, call the ones in your area
Kingkiller4316
Sep 23, 2021 09:10 PM
2009CivicParts
General 8th & 9th Gen
Jul 25, 2019 06:03 AM
speedfoos
May 15, 2007 04:58 PM
JoeyOKC
Arizona
16
Jan 13, 2006 12:26 PM
DizWikedCivic
Jan 8, 2003 04:30 PM
