Subframe bolt problem!
I’m in the middle of swapping in a K24 and using an EP3 subframe. One of the front mounting bolts for the subframe is just spinning and won’t tighten. Any suggestions on how to fix it?
thank you
thank you
Re: Subframe bolt problem!
Are the other three bolts already fully tightened down? Could cause an alignment issue making the bolt threads not grab.
Sure hope it isn't the nut loose in the frame.
blouisgod
May 5, 2004 06:51 PM
