Subframe bolt problem!
Old Nov 13, 2021
adam.binkley's Avatar
adam.binkley is an unknown quantity at this point
I’m in the middle of swapping in a K24 and using an EP3 subframe. One of the front mounting bolts for the subframe is just spinning and won’t tighten. Any suggestions on how to fix it?
thank you
Old Nov 13, 2021
Colin42's Avatar
Re: Subframe bolt problem!
Figure out if something is stripped or the nut in the subframe is loose
Old Nov 15, 2021
BrotatoChip's Avatar
Super Moderator
Are the other three bolts already fully tightened down? Could cause an alignment issue making the bolt threads not grab.
Sure hope it isn't the nut loose in the frame.
lollygagger
Aug 5, 2012 07:02 PM
VA_Civic
30
Feb 21, 2011 03:51 PM
greeen01civic4d
Nov 14, 2006 06:33 PM
theprophet36
Mar 30, 2006 07:18 AM
blouisgod
May 5, 2004 06:51 PM
