Car does not crank
Old Sep 12, 2021
Keylargo's Avatar
Keylargo is an unknown quantity at this point
Car does not crank
2008 Honda Civic - Doesn't want to start, all indicators light up, battery fully charge but won't turn on
Old Sep 12, 2021
Re: Car does not crank
check fuses under hood
Old Sep 12, 2021
Keylargo's Avatar
thank you, can you please be more specific. Cause they look fine
Old Sep 12, 2021
define "fine". There was one that opened the fuse box, simply glanced at the fuses and said they were fine...
not too many fuses, I would simply start pulling them out and check... should be faster than starting the computer, getting into the forums and typing a reply...
Old Sep 12, 2021
Keylargo's Avatar
there were no blown/burned out fuses. That's what I meant when I said they were fine
Old Sep 12, 2021
Do you hear a click noise when you turn key?
  • if yes, starter solenoid relay is working, but not turning
  • if no,
    • Check electrical contacts to the starter motor
    • Check if relay is working, replace as needed
    • solenoid is stuck, wack the starter motor.
    • check if no rodents chewed the wires (it's common...)
you can also use multimeter to check if no shorts (at the fuse box)
Old Sep 12, 2021
Keylargo's Avatar
Yes, starter solenoid is working, but not turning on
Old Sep 12, 2021
test your starter
Old Sep 12, 2021
watch this one too. Electrical parts have different placements than my 2002 car, so youtube is a potential source for solutions.
if you are lucky, you find some pearls like this one, luck you it is same year
Old Sep 12, 2021
test your starter
if starter is spinning, still need to check if solenoid is working and pushing the gear forward.
If not, smack the motor, it could just be stuck
Old Sep 12, 2021
Keylargo's Avatar
if stater is spinning, still need to check if solenoid is working and pushing the gear forward.
Thank you, I really appreciate your help. I need a new starter.
Old Sep 12, 2021
be careful, the 2nd video says that he got a new one that was not working properly.
test it before installing. end of the video, he showed how to test (you can actually test it before buying a new one, unless you already tested based on the videos) - i am assuming you did, from your reply...
purplepills
Electrical
Mar 31, 2020 09:06 PM
hawk72
Feb 4, 2020 11:32 AM
PKingFire
Sep 28, 2017 07:36 PM
mwrohde
Mar 24, 2017 07:56 AM
gOtRyce
Jan 19, 2005 09:43 AM
