Car does not crank
Re: Car does not crank
define "fine". There was one that opened the fuse box, simply glanced at the fuses and said they were fine...
not too many fuses, I would simply start pulling them out and check... should be faster than starting the computer, getting into the forums and typing a reply...
Do you hear a click noise when you turn key?
- if yes, starter
solenoidrelay is working, but not turning - if no,
- Check electrical contacts to the starter motor
- Check if relay is working, replace as needed
solenoid is stuck, wack the starter motor.- check if no rodents chewed the wires (it's common...)
watch this one too. Electrical parts have different placements than my 2002 car, so youtube is a potential source for solutions.
if you are lucky, you find some pearls like this one, luck you it is same year
be careful, the 2nd video says that he got a new one that was not working properly.
test it before installing. end of the video, he showed how to test (you can actually test it before buying a new one, unless you already tested based on the videos) - i am assuming you did, from your reply...
mwrohde
Mar 24, 2017 07:56 AM
gOtRyce
Jan 19, 2005 09:43 AM
